Scangauge II
Old Sep 7, 2016 | 05:56 PM
Rod Jr.'s Avatar
Rod Jr.
Scangauge II
Is there an x gauge to read fuel pressure on the 6.0 ?
Old Sep 7, 2016 | 06:22 PM
Mike189677's Avatar
Mike189677
There is no sensor so it won't work. It can't read what it can't see.
Old Sep 7, 2016 | 10:30 PM
Yahiko's Avatar
Yahiko
If only Ford had put that in. It would of saved a lot of problems IMHO.
Sean <BR>
6.0L Tech Folder
Old Sep 7, 2016 | 10:57 PM
04badford's Avatar
04badford
But you can pipe in a gauge off the fuel bowl test port .
Old Sep 7, 2016 | 11:23 PM
Blakshukvw's Avatar
Blakshukvw
My scangauge II won't show me a value for ebp. I programmed it to show this parameter. Is it possible the ebp sensor is deleted from the engine? Is that even something that can be deleted? I'm not sure exactly where it should be to look to see if it's still there.
Old Sep 7, 2016 | 11:27 PM
FiznUKa's Avatar
FiznUKa
If I'm not mistaken the EBP in the 03 is not used by the PCM. It should be by the thermostat housing or there abouts.
Old Sep 7, 2016 | 11:28 PM
04badford's Avatar
04badford
Check the Pid
Txd- 07e0221445 rxf-046285140645 rxd-3010 mth-0010050 mine 0ffb
Old Sep 13, 2016 | 09:55 AM
Rod Jr.'s Avatar
Rod Jr.
I contacted the manufacturer and told them I have Superduty 6.0 diesel, here is their response:
Fuel pressure is a standard gauge on the ScanGaugeII labeled FPR. If this gauge does not report, then there is an XGauge code available for this sensor. Using the following link https://www.scangauge.com/x-gauge-co...pecific-cansf/ you can access the XGauge for fuel pressure. On page 40 of the user manual you will find instructions on how to enter this code. If you have any questions, please let me know.
Regards,
Cristina Bollinger
Repairs and Technical Support
Linear Logic
1.888.433.5664
Old Sep 13, 2016 | 10:00 AM
Per4mance's Avatar
Per4mance
LOL......she don't know nothin about the 6.0. Write her back and tell her you need a real tech,see what she says.
Old Sep 13, 2016 | 09:05 PM
04badford's Avatar
04badford
maybe it's fuel level or miles per gallon. Wouldn't that be nice for fuel pressure
Old Sep 13, 2016 | 11:23 PM
87crewdually's Avatar
87crewdually
She's telling you generic info pertaining to newer vehicles such as GM gassers. There is a PID available for fuel pressure that you can monitor but NOT on a 6.0 diesel.
Old Sep 14, 2016 | 01:22 AM
Mike189677's Avatar
Mike189677
It sure couldn't have hurt especially if they had set it up to throw the wrench light like they did in the programming in the later truck for when the oil and coolant temps get to far apart.
To the op it doesn't matter how may times you ask liner logic the same question and they tell you it will work you have received the real answer here several times. Ford did not include a fuel pressure sensor so no matter how nice you ask the scangauge what the fuel pressure is it can't tell you. No sensor = no data. If you want to monitor fuel pressure you either need a stand alone gauge or an edge insight cts with the fuel pressure sending unit.
Old Sep 14, 2016 | 04:14 AM
Mcrafty1's Avatar
Mcrafty1
Regards,
Cristina Bollinger
Linear Logic
1.888.433.5664
She's telling you it's available on the SCANGAUGEII... which it most likely is....what she evidently doesn't realize is that the 6.0 doesn't have a FP sensor nor is it programed into the 6.0 PCM. Like the previous poster said....Scangauge can't read what it can't see.
Yahiko
Arizona Chapter
Oct 17, 2016 12:46 AM
Yahiko
Sep 19, 2016 05:16 PM
dhag911
Apr 30, 2016 03:03 AM
Jeffypop
Jan 25, 2007 11:42 PM
