Exhaust manifold differenced
Old Sep 6, 2016 | 10:44 PM
crucialprospect's Avatar
crucialprospect
I decided to go back with cast iron manifolds for my 86 460 truck build, are there any years that would be a better design than others? Originally mine had the a.i.r. bosses that I later plugged, but the manifolds for the d3 heads do not have these. Would the earlier dove headed manifolds flow better or are they all the same? The only problem I could see is if they don't put the collector flange in the right spot.
Old Sep 7, 2016 | 05:56 AM
Franklin2's Avatar
Franklin2
Make sure they are for 80-86 trucks or they may not fit.
Old Sep 7, 2016 | 12:48 PM
rowdyredneck's Avatar
rowdyredneck
As I recall the passenger side manifold is specific for trucks and vans. I did a 460 swap years ago into a F-150 and a car manifold would not work because of the angle of the pipe flange.
Old Sep 7, 2016 | 03:05 PM
crucialprospect
thanks all, I guess best bet is using the 80-86 style with plugs and tubes for the air system, just leave everything plugged up. I just have one late 70's d3 manifold and although it's still restrictive, it's not drilled and tapped and plugged, it just seems like it would have less turbulence.
quisp
Mar 18, 2011 09:44 PM
55 vicky
Jan 11, 2008 09:58 PM
Jim Larson
Feb 5, 2003 11:08 AM
The Man
Exhaust Systems
Jun 17, 2002 09:03 PM
dillon
Sep 25, 2000 02:02 AM
