Two different issues
Old Sep 6, 2016 | 03:19 PM
Smirks90's Avatar
Smirks90
So I need a new bed due to floor rot. Id like to find a replacement with the toolbox built in behind the passenger door. I know that's probably asking a lot but if anyone knows where one is on the east side of the country I am in Connecticut.
Second issue is the splines that connect my steering column to my steering shaft are stripped any ideas on how to fix that besides just tacking a weld on it. Thanks
Old Sep 6, 2016 | 03:33 PM
jowilker's Avatar
jowilker
Is your truck 2wd or 4wd? You will have to get out and beat the bushes on the bed.
John
Old Sep 6, 2016 | 03:54 PM
Smirks90's Avatar
Smirks90
its a 4x4 divorced t case
Old Sep 6, 2016 | 09:19 PM
Coastal68's Avatar
Coastal68
Seems like finding a decent bed with a tool box is a tall order. The boxes show up on eBay frome time to time. You might be better off locating good examples seperately. 67 72 Ford Truck F150 F250 F350 Bed Side Tool Box Door Latch camper Storage | eBay
Old Sep 6, 2016 | 09:25 PM
Smirks90's Avatar
Smirks90
yea i have considered that. i just don't know how good it would come out just ripping a hole in the side of the bed and sliding that in. its too bad my floor is rotted because the rest of the bed is in good shape. the problem is someone just laid down some diamond plate steel on top and body sealed it in place.
Old Sep 6, 2016 | 11:37 PM
orich's Avatar
orich
Aw yea that's the same thing what happen to my.
It took me 2 months before the junk yd called me that located one for me. $250 this was in 1979 I call up to 200 miles away. and the last yard, I called a 50 miles but he posted on the junk Yds hot parts locater that the got one.
No tailgate but had the side tool box in good shape.
But One problem, in order for the mounting holes to line up.
What, I had to do was dent in the back side at the spring eye bolt head area cause it came in contact with the backside of the box.
I later cut a 3x4" square access to remove the spring bolt. I made a sheet metal door and seal with a light coating of seam sealer.
Orich
Old Sep 7, 2016 | 01:14 AM
GaryKip's Avatar
GaryKip
Have you considered installing a metal hatch cover (for a boat)? you can get a size that you want, and they're water proof. Check out Cabela's online.
Bump Lives matter!
Old Sep 7, 2016 | 04:15 AM
GaryKip's Avatar
GaryKip
More info:
Tempress® 1330 Access Hatch with Cam Latch
  • Ideal for creating all types of storage
  • Corrosion-resistant hatch covers with O-ring seals
  • Designed for either vertical of horizontal use
  • Structurally reinforced for heavy traffic areas
Tempress Access Hatches are ideal for creating all types of storage, baitwells or livewells and electrical-line or fuel-line access points. The corrosion-resistant hatch cover and flange feature an integral hinge and cam-latch closing system that combine with a weathertight O-ring seal to ensure stored items stay dry and protected. The hatches are designed for either vertical of horizontal installation and are structurally reinforced for heavy traffic areas. Comes with with dual cam latches.
Hatch size: 13" x 30" outside; requires 10-5/8" x 27-1/2" cutout.
Colors: Dark Gray, White.
Check if this item is in stock locally
Color Size Cut-Out Size Quantity Price In-Store Availability Dark Gray 13" x 30" 10-5/8" x 27-1/2" Regular Price: $119.99
Limited Stock
Please choose a store to see what items are available locally.
White 13" x 30" 10-5/8" x 27-1/2" Regular Price: $119.99
Limited Stock
Recently Viewed
See All 4 Items
TH Marine Designer Series Storage Hatches
Cabela's White Lockers
Custom Hatch
See All 4 Items
Old Sep 8, 2016 | 11:45 PM
Smirks90's Avatar
Smirks90
i am trying to keep the look of it stock. just thought it would be cool to find one with the box. i really don't need it. i would just fix my bed if i knew a good way to do it. like i said the bed sides are perfect and straight so frustrating.
Old Sep 9, 2016 | 12:57 AM
GaryKip's Avatar
GaryKip
I don't know why someone couldn't cut out the floor of the bed and replace it with aluminum plate or aluminum diamond plate, or steel for that matter. Then paint it with bed liner. I've seen pics of full sized trucks with the wood kits too.
Old Sep 9, 2016 | 06:36 AM
Coastal68's Avatar
Coastal68
I'm guessing the rot is too severe to just weld in new sheet metal.
Ford - Ford Pickup Truck Metal Bed Floor Section - Approximately 16 X 48 - Macs Auto Parts
https://www.npdlink.com/store/produc...416-50892.html
Old Sep 9, 2016 | 08:49 AM
orich's Avatar
orich
I remember on this bump site that someone had ordered the patch panels an the corrugation width was different an did not line up with what was in their bed.
Boy that should look good!
I have seen many bumps with the side tool box in the junk yds here in my area in past yrs. But now days have not seen a bump in six months at any of the four Junk yds PnP with in 50 miles.
The big cities have run out of monthly in put of these old iron classics.
The ol cash for clunkers causes many people to turn in many classics at such a high rate they flooded the junk yards then.
Now days theirs not any siting around like was before in peoples back part of their drive ways with flat tires.
Orich
Old Sep 9, 2016 | 11:08 AM
RichS2659's Avatar
RichS2659
Keep an eye on Craigslist or other ads for pickup bed trailers. Many were hacked into a trailer when the engine or tranny gave out. Some can be pretty pristine in their condition. Also, wasn't it fellow FTE'r Randle who totally rebuilt his box from many parts?
Livewyre
15
Jan 9, 2018 11:53 AM
HillBillyBuddha
May 21, 2013 12:49 AM
61fordf25
Dec 15, 2010 01:06 PM
lariatboy302
Paint & Bodywork
Oct 4, 2004 02:48 PM
jl4x4
Oct 19, 2003 11:29 PM
