I think what I need is the equivalent to the Dorman 746-147.
I looked for them first at AutoNation Ford White Bear Lake (because I like sticking with one vendor if I can) but I struck out. I did found two of them for $23+ instead of $33 each from Dorman on Amazon so I think I'll go that route unless someone's had a terrible experience with the generics.
I found a walk-through on a similar age of Bronco at another forum
I'll have to wait until I get the replacement parts to see what size bolt I'm going to need.
I had to replace the latch cable on my 95 F150 recently. In order to do that, I had to drill out the rivet for the lock actuator. There was no way to remove the latch without removing the actuator. Are you saying your electric window motors are missing? If possible, do those at the same time and you will save some time. I also had to replace my window motor so did it at the same time. Good luck.
When those motors freeze up, you can't operate the locks from inside or out. Thus likely why they took it completely out of the door. I had the same issue with my '89. Couldn't turn the key or lift the handle to unlock the door, so I had to leave it unlock all the time.
Replaced the motors and works perfect.
If the white clip is not broken, you can reuse it and mount the new actuator in it, thus you won't have to drill the rivet out(been there, done that). Takes some dexterity to get your fingers down in there to get the rubber bushings installed, but that is the worst part of it. Plug it in and go.
I've gotten replacements from Autozone, can't recall what brand. Worked for many years that I had the truck.
How are you planning to attach the new mount? I used a bolt and nut, which worked OK for installation because I was able to get it tight without needing a wrench on the inside. But I think if I ever have to disassemble it I might be in trouble (although grinding the bolt head off is always an option).
Using a rivet would make it easier to drill out again next time, but it is a big rivet, bigger than mt pop rivet tool will do.
I epoxied a short bolt to the bracket. I let it cure good then put the actuator in the bracket. I used a self locking nut on the outside of the door. I did not have any trouble getting the bolt tight. I want to get some touch up paint for the nut to match the truck and make it look better.
Currently I've got a standard screwdriver head 1/4" bolt pointing outward with a matching large washer & nut on the exterior. I can get a screw driver down into the door cavity much easier than a ratchet can be used so I went with that.
I might dremel off the extra length of the bolt to minimize it catching on things, and possibly paint it. But frankly I'm not to worried about that now.
If I can find the proper rivet that'd be great. Then I'd need to find someone who owns a BIG rivet gun to do me a favor. That's a stretch so I'm currently just planning on going with what I have.
I'm not sure if everyone had difficulty getting the actuator in the bracket but I did. I think it would have been very difficult to put the bracket in the door, then install the actuator. With the actuator in the bracket, I'm not sure you could get a screwdriver behind the actuator. Let us know how you end up doing it. I still need to do my passenger door. Good luck.
I just removed the actuator from the bracket (easy peasy) and was left with the bracket. I spent more time debating what size bolt head would clear the bracket than I did messing with the bracket/actuator itself.
