Anyone running the Bar None fuel setup? Pics?
Shawn, I had to mount mine on the outside also. Not enough room between the front tank and tcase.
On mine the brake cable ran between the filters and bracket.
Works fine out there. So far no problems with rocks kicked up off the wheel.
Whats really funny is they paint the brackets in rustoleum hammer black paint which is exactly what i painted my entire truck in haha
I've got the pump and filters just hung for now, i abandoned their clamp around the frame style since mine is a cab and chasis and i am trying to avoid drilling through 1/2" of steel so i just redrilled the bracket. I'm also going to see if can get a 3/8" quick connect fitting and use 3/8" hose directly from the sender and i am going to have ESCO make up a braided stainless line that runs all the way up the frame and goes to the regulator.
That'll eliminate 2 65psi brass to stainless compression fitting with 4 65psi hose barn connections and leave it with just 2 #6 JIC connections. The only compression fitting ill have is on the return line from the banjo i believe, and i might get that made as a small flexible stainless line too.
I didnt cut the stainless supply line feed from that, i ran some of the fuel line directly from the top of the FSV to the pump/filter inlet. It was a 5/16" connector with 3/8" line but i put 2 hose clamps on it and i think it'll be alright until the the 5/16" x 3/8" adapter gets here. I also tried to go straight into the banjo fitting with a line instead of a loop of hose like in the directions. It offers some support to the banjo fitting that would just bounce around.
The hose supplied is is some parker 350psi rated fuel line. Its extremely hard to push the rubber onto the connectors without any lubrication. I snugged every connection with a hose clamp even though its push lock.
The harness is extremely high quality. Every connector was labeled and not just crimped on but heat shrunk too. Also, dont paint over the paint with more pant even if its teh exact same paint haha. It must have been pretty fresh because it orange peeled up.
Similar to this.
Also put in a filter minder. These are so much bigger, they'll hold a lot more crap.
