GVWR Questions
Old Sep 5, 2016 | 09:42 AM
DDDDDMorgan's Avatar
DDDDDMorgan
GVWR Questions
Once again I will confess to idiocy and beg forgiveness.
My question is thus: I have a GVWR rating on my 86 F150 of 7,001 with a max tow rating of 7,500; how does the trailer translate to GVWR?
Does the pin weight (or tongue weight on bumper pull) add to the GVWR?
Can I load my truck up to 7,001 lbs and then pull 7,500? That sounds crazy!
Thanks
Old Sep 5, 2016 | 09:50 AM
RV_Tech's Avatar
RV_Tech
Don't forget the GVWR rating includes what the truck weighs and the pin weight adds in as does everything you put into the truck including you and family members and fuel and the list goes on, so you may not be able to add as much as you think to reach your GVWR.
Steve
Old Sep 5, 2016 | 01:21 PM
r2millers's Avatar
r2millers
To answer your last question, you need to find the GCWR. That the gross combined weight of both the truck and trailer.
Many newer F-250 trucks will be upwards of 15,000 lbs. Not sure about your older 150.
Old Sep 6, 2016 | 08:30 AM
jchristian11's Avatar
jchristian11
My 2014 F250 has a GCWR of 23,500 lbs
Old Sep 6, 2016 | 11:15 AM
r2millers's Avatar
r2millers
Yep. Correction, mines at 23,000 lbs. My brain kept thinking tow weight.
rambo3489
All Things Towing
55
Sep 5, 2019 02:47 PM
Joshua Hurst
Jun 5, 2017 11:09 PM
fordmanva
All Things Towing
19
Mar 27, 2013 01:14 AM
saysay
All Things Towing
Nov 29, 2005 10:24 AM
sty
All Things Towing
Mar 5, 2004 01:18 PM
