head light switch help
Old Sep 5, 2016 | 08:56 AM
#1spudman's Avatar
#1spudman
i have a 1951 ford head light switch and a 1989 ford steering column all the light's work
ok but wen i step on the brake's both turn arrow's light's come on at the dash
what em i doing wrong help me help me i fallen a i can't git up
#1spudman i need all the help i can git
Old Sep 5, 2016 | 09:20 AM
moejr's Avatar
moejr
recheck your wiring, your getting voltage feedback to the turn signal circuit. I'm not sure if 51 came with turn signal lights.....did you add them?
Old Sep 5, 2016 | 09:40 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe
T/S were an option in 51. Yes, something is wired wrong. Do your emergency flashers work correctly? With that newer column, how many wires go to the turn signal circuit?
Old Sep 5, 2016 | 09:47 AM
#1spudman's Avatar
#1spudman
no it came with them a left and right arrow in the speedometer < - >
Old Sep 5, 2016 | 10:05 AM
#1spudman's Avatar
#1spudman
yes the emergency work ok im thinking it's 5 maybe 6 it's not here at the house i have to git back with you on that one #1spudman thanks
Old Sep 5, 2016 | 11:13 AM
#1spudman's Avatar
#1spudman
there are 6 wire on the light switch
thanks
Old Sep 5, 2016 | 01:44 PM
#1spudman's Avatar
#1spudman
i found a diagram that has 6 post it a pane & deluxe cab only are all six post the same ?
Old Sep 5, 2016 | 06:07 PM
rdemilt's Avatar
rdemilt
Check the wiring and sockets of the tail lights themselves. I've seen problems as simple as the bulbs being installed incorrectly.
Old Sep 6, 2016 | 11:09 AM
CaptPayne's Avatar
CaptPayne
Weird electrical gremlins like this are usually a bad ground connection. The turn signal indicators are coming on with the brakes as that is the easiest ground source for them. Make sure the lamp socket is corrosion free, and the tail light has a good clean spot to ground to the frame.
Old Sep 6, 2016 | 10:49 PM
Bluey Zedoff's Avatar
Bluey Zedoff
I agree. Check your earths. I had left blinkers working the brake lights, right blinkers working the reversing lights and brake lights working the number plate lights. Just one loose earth fixed the lot.
79F250isalive!
Feb 7, 2015 07:07 PM
swood0580
Feb 14, 2013 08:14 PM
carbs & chrome
Oct 8, 2011 09:13 PM
kaimi01
Sep 27, 2011 10:28 PM
74 F100 351m
Nov 24, 2003 12:28 PM
