E4OD blow'd up
Old Sep 4, 2016 | 09:14 AM
96_F250_Deezal's Avatar
96_F250_Deezal
E4OD blow'd up
Neighbor brought me a E4OD transmission to look at, he removed it from his 95 F-250 2wd truck, 5.8L gas engine.
Pulled the extension housing off and immediately found the issue. The thrust bearing between the case and output shaft/parking pawl had come apart and the parking pawl had damaged the case. output shaft had nearly 1/2" of movement.
pulled the transmission apart, all the clutch packs are burned to a crisp and the case is damaged beyond repair.
96_F250_Deezal
All Other Items for Sale
May 2, 2013 11:33 PM
jowens1126
1978 - 1996 Big Bronco
Mar 22, 2013 07:41 PM
96_F250_Deezal
Jun 29, 2011 10:53 PM
Big95Bronco
Jun 4, 2008 10:17 PM
Manwith3fords
Offroad & 4x4
Dec 26, 2007 09:00 PM
