1978 - 1996 Big Bronco
Weird Spark Problem
Old Aug 20, 2003 | 06:03 PM
Bignorse's Avatar
Bignorse
Exclamation Weird Spark Problem
Hi,
I have a 91, with 351 and EOD4 xmission.
I start her up, and she runs pretty rough. I turn all the lights off in the garage, and I can see corona comming out from under the plug boots on the passenger side. I occasionally see a arc from one of the wires to the rocker cover as well..
I have changed the plugs, wires, cap, rotor, even the distributor (hall effect senson and control module). After all that it is only slightly better. Still runs a little rough but better. I also see a lot of sparking.
The last thing I can change is the coil, and condenser.
I am at my wits end with the old girl.
Any Ideas?
Just trying to keep the spark in...
Old Aug 20, 2003 | 06:55 PM
DW2455's Avatar
DW2455
Weird Spark Problem
this may sound stupid but i've had this happen to me, if you've replaced everything, then put your old distributor cap back on, dont bother anything else just the cap. and see what happens. DW
Old Aug 21, 2003 | 10:17 AM
BillyBob69's Avatar
BillyBob69
Weird Spark Problem
Wow...I have had that happen but I just repalced the wires and it was fixed. Seems like you have an awfull lot of power running through the wires to get it to pass through the boots and shielding. Only thing I could suggest would be make sure the boots are all the way down over the plugs and be carefull not to nick the wires when installing them. A slight scrack on the shielding can cause a external arc like that. Good luck on it
Broncobudy
36
Sep 24, 2010 02:41 PM
tjs_79ford
Sep 20, 2009 11:30 AM
mike L
Mar 4, 2006 06:13 PM
jkj4498
1983 - 2012 Ranger & B-Series
26
Apr 29, 2004 11:05 PM
wally2117
Aug 27, 2002 10:20 PM
