high beams not working
Old Sep 1, 2016 | 01:03 PM
eaglefire21's Avatar
eaglefire21
I have replaced mfs less than a year because of high beams not working, last night working fine, oncoming car passed and hit high beams nothing, light on dash shows highs on
Old Sep 1, 2016 | 05:00 PM
tjc transport's Avatar
tjc transport
i ain't rite
first thing i would do is check the bulbs. many many times i have seen cars/trucks come into the shop complaint no high beams or no low beams. 99% of the time new bulbs fixed the problem .
Old Sep 2, 2016 | 11:31 AM
lee00's Avatar
lee00
remember not to touch the bulbs themselves...causes premature failure...
Old Sep 2, 2016 | 01:31 PM
madpogue's Avatar
madpogue
^^^^ +1 above; if the dash indicator lights up, the switch is most likely good. Easy enough to check for voltage at the high and low terminals on the connector at each lamp. Are you running a relay harness, by any chance?
Old Sep 2, 2016 | 03:04 PM
eaglefire21
I am running a high output harness with relays, this has happened before I replaced mfs, wandering what is causing it to burn out
Old Sep 2, 2016 | 03:36 PM
knottyrope's Avatar
knottyrope
possible relay not rated for high enough amps or contacts burned or coil burnt out or fuse or lost a ground
Old Sep 2, 2016 | 07:26 PM
madpogue's Avatar
madpogue
Did you test/swap the relays? (Presumably separate relays for low/high...)
BTW, always good to mention aftermarket/mods that might be relevant in the opening post. Also wise to start troubleshooting with any aftermarket/mods that might be associated with the problem.
Old Sep 3, 2016 | 09:21 AM
eaglefire21
I will check relays and do a ground check any tips on grounds other than the obviouis ones today, you are right I should have stated about the aftermarket parts I was trying to figure out why if it is whats shorting out the mfs, found the one I replaced still in the garage , I don't want to start a collection of them
Old Sep 3, 2016 | 09:36 AM
madpogue's Avatar
madpogue
If the low beams are working, it's most likely NOT a ground, except perhaps the ground for the high beam relay. One thing you might try is the old "revert to stock" troublshooting tip - disconnect the relay harness and connect one headlight directly, and re-test.
Old Sep 17, 2016 | 08:49 AM
eaglefire21
relay was the problem, both have corrosion on the same terminal, replaced them and put elc grease to help protect them
Old Sep 17, 2016 | 09:05 AM
madpogue's Avatar
madpogue
Which terminal was it? The corrosion may indicate an issue elsewhere.
Old Sep 29, 2016 | 12:13 PM
eaglefire21
The relays are four terminal and the lower left looking at terminals on both high and low relays
aaronboehmke
2004 - 2008 F150
Dec 22, 2015 05:35 PM
boggerted
Mar 21, 2012 02:05 PM
Rattler60
Sep 30, 2010 10:16 PM
wgking
Feb 12, 2007 10:12 PM
