sputters
Old Aug 31, 2016 | 09:36 AM
Danny2016's Avatar
Danny2016
sputters
I have a'04 f-250 6.0L diesel truck. There are times when i come to a stop that my truck sputters like if it's about to run out of fuel or want to shut off but the tank is full or half. If i am going at a fast pace and then begin to slow down and stop it will sputter. Any ideas?
Old Aug 31, 2016 | 10:17 AM
Don Naslund's Avatar
Don Naslund
Do you have gauges? What is the high pressure pump putting out? If it goes below 500 pounds, it will die on you. We need to know the health of the other components. They all depend on each other to keep the engine running smoothly.
Old Aug 31, 2016 | 10:30 AM
Maxium4x4's Avatar
Maxium4x4
Would a rolling idle or surging describe it better? Unplug the ICP sensor and give it a go. Early 04 is under the turbo, late 04 is on the passenger side valve cover.
Old Aug 31, 2016 | 11:50 AM
Danny2016's Avatar
Danny2016
Guage is fine....i had the oil pump replaced because i was having problems with high oil pressure which 6.0's have and i replaced an injector. I just replaced the radiator and the mechanic did a block test due to the bad radiator. Of course that test doesn't really tell you anything other than the radiator was busted which anyone could have identified.
Dixieland Diesel
Feb 13, 2013 07:13 PM
dbarnett42
Jul 8, 2012 10:58 PM
FordOwnerJoey
Feb 27, 2012 11:03 PM
rowall
2004 - 2008 F150
Aug 4, 2004 09:04 PM
Bohunk Farmer
Mar 25, 2004 02:06 PM
