Air compressor failure?
Old Aug 30, 2016 | 05:23 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
04 Navigator.
This morning the suspension on the navi wouldn't air up. Wife drove it to work and home before I found out about it. The compressor is running, but sounds funny. Faster and higher pitched than normal.
Since the suspension is flat all the way around I suspect that the wrist pin broke on the piston and is letting the pump free spin, as opposed to a height sensor or bag failure.
I'm running to oreillys now to get a pump. Just wanted to throw the symptoms out to the board to see if it sounds familiar to anyone and find out what your fix was.
Thanks!
Old Aug 30, 2016 | 06:52 PM
r2millers's Avatar
r2millers
Wow, I'm not really sure you'd se a wrist pin break as noted. Maybe?
Did you check your bags leaking as that's pretty common and also, the splice in the rear line right over the power steering pump. It too can develop a leak and keep the bags from filling.
Old Aug 30, 2016 | 09:31 PM
cookie88's Avatar
cookie88
FTE Emeritus
Thanks. If I remember I'll take some pictures tomorrow. The piston and rod were little more than chunks and dust.
Can't hear the new pump running at all, which is cool. Also, oddly, the front end sits about an inch higher than it has in years. Also cool. That pump had been trying to die for a long time as it turns out.
Old Aug 31, 2016 | 08:36 AM
alloro's Avatar
alloro
Without first finding out what is wrong? It could just as easily be a broken air line and the pump sounds different without any load on it. Yes it could be the pump, but that's a good chunk of change to shell out on a guess.
High_Horse
Feb 24, 2011 04:06 PM
2000-EB-EXPY-AWD
Oct 8, 2010 01:05 AM
Icefan71
Oct 13, 2006 01:47 PM
fattmann
Aug 14, 2006 01:15 PM
akita
Apr 16, 2005 09:46 PM
