General Automotive Discussion
Key duplicates
Old Aug 29, 2016 | 04:53 PM
NathanEHarvey's Avatar
NathanEHarvey
Key duplicates
I'm down to my last key and am having trouble finding a place that can make duplicates for me. I've gotten one that will open the door, but not engage the ignition. Is this something you have to get done at the dealership?
Old Aug 29, 2016 | 10:23 PM
ford2go's Avatar
ford2go
Welcome to FTE
Could use a few details about the key trype. If it's an electronic key, you might have to go to a dealer -- or at least a locksmith (might be cheaper).
They've started this 2 key business to reprogram them from what I understand. I imagine that they will say it's for security. Don't expect it to be cheap if it'ss a programming deal.
hj
Old Aug 31, 2016 | 01:07 AM
gicoastie's Avatar
gicoastie
Hi Nathan,
Is it the key cutting that is giving you a problem? Will the key not turn in the ignition? If the key cut is fine and the vehicle will not start when the key is turned, then the key has not been mated to the PATS system. Does not matter if the vehicle is keyless or has a key, there is two different coding's required to make the key work. One for the door lock and the other for the ignition. I would suggest you go to a dealer and get it sort out.
banshee_man_96
Nov 22, 2018 07:20 AM
2civicrr
6.7L Power Stroke Diesel
19
Apr 10, 2018 11:00 PM
Thorium
2015 - 2020 F150
23
Nov 17, 2016 12:34 AM
RavageX
13
Apr 4, 2013 01:35 PM
KWest
Apr 16, 2006 12:26 PM
