Horn problem
Old Aug 29, 2016 | 02:14 PM
Damifiknow's Avatar
Damifiknow
Horn problem
Most of the time its works fine. Seems when truck gets higher temp the horn doesnt work until the engine cools down little. Thoughts?
1979 F100 302 auto
Old Aug 29, 2016 | 03:35 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Does your truck have factory cruise control?
Old Aug 29, 2016 | 04:14 PM
Damifiknow's Avatar
Damifiknow
no cruise control.
Seems like when truck gets hot it stops and when it cools down it works again. Not sure if anything else is going dead like lights cuz i really only drive it during the day.
Old Aug 29, 2016 | 04:58 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The reason I asked is because on 78 & 79 models the horn wiring is different between with and without cruise.
On models without cruise, the horn button is an actual power switch, not just a ground circuit like earlier trucks.
Your truck does not have a relay and I can't really see anything in the cab that engine temps would affect.
I would check the horn wiring in the engine compartment and also I would clean and check the terminal connection on the horn(s).
If all of that checks out I would tear down the horns and clean up the contacts inside. They are actually pretty simple inside. I rebuilt mine and posted a thread on the process:
https://www.ford-trucks.com/forums/1...horn-work.html
Old Aug 30, 2016 | 07:25 AM
Damifiknow's Avatar
Damifiknow
Horn is new. I'm gonna change steering wheel soon and see if i find something then.
Old Sep 7, 2016 | 09:11 AM
Damifiknow's Avatar
Damifiknow
Still having intermittent horn problems. Waiting at a drive through yesterday and pulled away I needed horn and it didnt work.. drove for about 2 block and Viola it worked again. WTF?
Old Sep 7, 2016 | 09:48 AM
HIO Silver's Avatar
HIO Silver
I suggest installing a jumper wire across the rag joint. I recall there is a thin copper bonding wire there that might be broken and working intermittently.
Old Sep 7, 2016 | 10:09 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Like this.
Old Sep 7, 2016 | 10:12 AM
HIO Silver's Avatar
HIO Silver
Like this.
Yup. Thanks for the pic... maybe it solves the OP's problem.
Old Sep 8, 2016 | 07:44 AM
Damifiknow's Avatar
Damifiknow
Ill try it thanks
Old Sep 8, 2016 | 09:15 PM
weldman's Avatar
weldman
Having issues myself, wondering if this fixes it.....wait a minute, I think I got rid of the rag joint years ago....
puck1263
Jul 11, 2012 01:45 PM
broncster
1978 - 1996 Big Bronco
Oct 29, 2006 02:34 PM
shrug
Nov 29, 2005 08:47 PM
MOC
Aug 14, 2005 09:55 PM
docholiday72tx
35
Jan 16, 2005 11:05 PM
