VIN decode needed
Old Sep 1, 2016 | 07:03 PM
classictruckman's Avatar
classictruckman
Miraculously the axle tag is still there, it's barely legible. Is there a certain order to the letters/numbers on the tag?
Old Sep 2, 2016 | 10:07 PM
classictruckman
Anybody know the #-A sequence Dana used?
Old Sep 3, 2016 | 05:32 PM
classictruckman
Ok, so I took a wire brush to the axle tag and the numbers look like this:
4 09 D3TA
603395-1
Does this look right to anybody? And if so what does it translate to?
Old Sep 3, 2016 | 06:13 PM
Filthy Beast's Avatar
Filthy Beast
A good read here:
https://www.ford-trucks.com/forums/9...-44-parts.html
Old Sep 3, 2016 | 09:05 PM
classictruckman
Thank you very much Filthy Beast, that's exactly what I was looking for. So I have the 3500lb front axle.
Old Sep 4, 2016 | 12:10 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford: D3TA-GA / Dana: 603395-1
So I have a 3500lb front axle.
No...you don't.
D3TA-GA/603395-1 = Dana 44-6CF Front Driving Axle - 4.09-1 with free running hubs; no Limited Slip; 3.3M (3,300 lbs.) front axle capacity.
Original application: 1973 F250 Regular Cab 4WD 3,300 lbs. capacity front axle with P/S
Pic: 7th entry in column left:
Old Sep 4, 2016 | 04:35 PM
classictruckman
Thanks NumberDummy, guess i'll order the parts for the 3300 lb axle.
That list contradicts your first post in the link Filthy Beast posted:
Dana ID number: 603395-1 / Ford ID number: D3TA-G = Dana 446CF / 4.09-1 / non Limited Slip / 3,500 lb. Front Axle Capacity / Free Running Hubs / Front axle parts list number 30.5C
Original application: 1973 F250 4WD.
C7TZ3220A .. Left Axle Shaft Assy / 28 11/32" long / Obsolete / Fits: 1967/77 F250 4WD.
B9TZ3249A .. U-Joint / Obsolete / Fits: 1959/77 F250 4WD.
No Ford Dealer or obsolete parts vendor has the axle shaft assy, which included both the inner and outer shafts.
Found a gazillion U-joints.
61 uni
Oct 7, 2012 08:20 PM
mtpcage
2004 - 2008 F150
Jul 26, 2010 02:04 PM
72f250CS
Jan 31, 2010 06:49 PM
seth_85
Jan 23, 2006 03:46 PM
mrsuperman15
Oct 25, 2003 10:08 PM
