While i was trying to park, i heard a clunk, wheels stayed in the same position. The steering wheel is loose as hell, it literally feels like its buttered up and wont turn the wheels at all, any ideas on what to buy to fix it? Im thinking i just need a new gearbox but i want other opinions
Reason: Misspelled
What are the details of your truck? Year Model 4 or 2wd? I had a the output shaft break on my 1999, they are prone to this when a drop pitman arm is installed and the nut backs off.
You need to have someone turn the steering wheel back and forth while you look underneath to see what's not moving.
The pitman arm might have come loose from the steering box, the steering shaft might have come loose from the input shaft, the drag link adjuster might have rotted through, etc.
Be careful not to spin the steering wheel. You'll break your clock spring if the wheel is turned too far, or reconnected a full turn off from what it should be. I'd seatbelt the wheel into place once you figure it out, and reset the clock spring when you get it back together.
