Concerning oil change
I only recovered 6qts!
There is a leak, which I think I've narrowed down to the passenger side valve cover. I pressure washed engine this weekend and will be extra attentive next several hundred miles so I can spot it's origin(s).
None the less though. How does the engine allow itself to get that low, and not throw a light on the dash?
There isn't a low level sensor to indicate this. Only a dipstick you can check on a regular basis.
https://www.amazon.com/Tracerline-TP.../dp/B004IQ9IY6
When injector O-rings fail, the truck burns oil fast without making a lot of smoke. What color is your fuel filter?
If only 6 qts came out when you drained it, you must have left some trails around!
Tugly - fuel filter color? not sure, I know it (or they if there's multiple) where changed last time it was at dealer at @ ~115k.
I'm @ 125k now, but religiously use Opti-Lube XPD at with every tank.
Fuel filter change interval is ever 15k right?
CampSpringsJohn - Your valve cover bolts rusted out?! on your 2008!? That's outrageous! I hope not/doubt that's what I have, I'm second owner and its entire history was in Texas.
You'd think I'd be leaving trails, but I assure you I'm not. I have at both home and work, long white concrete driveways. Not a drop anywhere, not at cold starts when leaving or idling in after a 30min interstate drive when returning at either location.
Maybe it only leaks/gushes at WOT? Or somewhere up in the Rev's but just not at idle?
AllaboutMPG - yea, I know there will always be some left that can't be drained + just what lines all the inner crank parts and walls is prob another qt. None the less though, when filling, it takes 16 to land level appropriately on dipstick.
Rikster-7700 - there was a very considerable amount of caked on [oil based] road grime on the right side of engine bay, inner cooler plumbing, frame, a/c compressor and even on the hood insulation. Its mostly clean now thanks to 3000 psi of water
I've only driven maybe 15miles since cleaning it all, and don't notice any new oil anywhere yet.
schlepprock250 - last oil change was on point @120k, this one was actually a bit early @124,700 just cause I had the time now, and know I won't in the next few weeks. Couldn't tell you when chronologically off the rip, longer than average though, its not always someone's daily driver. Maybe 6-8 months ago?
Oil that came out was of expected viscosity, no sludgy characteristics
It was 4 qts down somehow and started right back up after I added oil. That's when I learned about the HEUI's from taking it in to a diesel mechanic. Never knew what happened. I don't know how your engine continued to run....
So, this must mean I have some super awesome internal parts right?
What he is referring to is the actual color of the filter media after removing from service. The filter media is white when it goes in. Diesel fuel will not drastically discolor the media. If you remove the fuel filter and the filter media is black or just really dark and any shade other than white/off-white is usually an indication of leaking injector orings.
Sometimes its a big power loss prior to engine shut down
