Glow plug replacement question
Old Aug 26, 2016 | 10:40 AM
tnwill's Avatar
tnwill
Will be replacing vc gaskets, uvch's, and glow plugs this weekend. Do you guys who have performed this before use any type of anti-seize compound on the gp threads? In my industrial mechanic experience, I have always used anti-seize on hot applications where there is a possibility of galling. I would be using Felpro N-5000, nuclear grade nickel base compound.
Old Aug 26, 2016 | 10:45 AM
white Buffalo's Avatar
white Buffalo
I have only done it 4 times, but never had an issue removing the old plugs. I believe the majority here have experienced the same.
Old Aug 26, 2016 | 10:47 AM
white Buffalo
But do check the wire harness that rests on the drivers side valve cover. That tends to wear through the wire insulation. I put some liquid electrical tape on the wear spots then wrap it with some electrical tape as well.
Old Aug 26, 2016 | 11:11 AM
HKusp's Avatar
HKusp
Make sure to only use Motorcraft GP's or all the antisieze in the world isn't going to stop the aftermarket ones from swelling up and needing to be removed.
Old Aug 26, 2016 | 11:15 AM
knottyrope's Avatar
knottyrope
I used engine oil to lube them.
Old Aug 26, 2016 | 12:11 PM
tnwill's Avatar
tnwill
Thanks for the info guys. The wiring harness over the valve cover was the first place I looked when I started troubleshooting. It all looks good. 8 new Motorcraft Gp's are laying in the front seat now.
Old Aug 26, 2016 | 01:09 PM
z31freakify's Avatar
z31freakify
Don't use any antisieze the engine oil keeps them from seizing.
tassmannn
May 16, 2017 08:41 PM
riverstorun
Sep 11, 2015 01:16 AM
97biostroke
Feb 8, 2009 01:51 PM
dyoungen
Oct 24, 2008 09:17 PM
ac1108
Dec 4, 2006 11:43 AM
