A/C Blower Issues
Old Aug 24, 2016 | 08:10 PM
Rose88racing's Avatar
Rose88racing
A/C Blower Issues
When you first crank the truck it will blow fine through all speeds, and cold
Just replaced the Compressor 3 months ago.
Air is cold but seems to not flow or blow as hard after truck warms up.
Sounds rough in the glove box too. When you turn it to high it makes a roaring
noise.
Any ideas? Replaced the compressor because clutch was gone on other.
This new compressor has a lot less air gap. Has worked fine since replacing until this week.
thanks
Rose88racing
2000 F350 7.3
Old Aug 24, 2016 | 08:26 PM
schlepprock250's Avatar
schlepprock250
Check above the passenger floor board and make sure there's nothing blocking the return.
Old Aug 24, 2016 | 08:34 PM
163junk's Avatar
163junk
Sounds like blower motor dying, or something in heater box hitting wheel.
Pikachu's Avatar
Pikachu
Does the airflow decrease gradually, or suddenly?
Old Aug 24, 2016 | 09:34 PM
schlepprock250
Recently my fan seemed weak, didn't blow as hard as it did before. I found a Walmart bag had been pulled up through the return.
Old Aug 25, 2016 | 05:17 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Coils may be dirty restricting flow then freezing up restricting flow further.
Old Aug 26, 2016 | 08:22 AM
Rose88racing
Ran over a few bags on the highway I will check that
Old Aug 26, 2016 | 08:24 AM
Rose88racing
I would say gradually, Hard to say by the time I realize it I move it to the next setting speed. The temp never gets warm so I rule out the blender door.
Old Aug 26, 2016 | 11:04 AM
HKusp's Avatar
HKusp
If it's gradual, this sounds like the most plausible answer to me. There also may be a bag, or partial restriction adding to the problem, but this makes sense to me.
Old Aug 26, 2016 | 11:07 AM
schlepprock250
The bag that got sucked up in to mine was from the floor board.
Old Aug 26, 2016 | 11:45 AM
AllaboutMPG's Avatar
AllaboutMPG
The blower fan and resistor are pretty easy to pull out. less than 10 minutes and you'll know if it's something in the fan area.
Old Aug 26, 2016 | 12:47 PM
Rose88racing
Pics of under wiper cowl seem fine nothing there
Old Aug 26, 2016 | 01:04 PM
schlepprock250
On max ac it pulls air from the passenger floorboard.
Old Aug 26, 2016 | 01:12 PM
Rose88racing
That opening is clear can see through it with blower out. The coils are cover in debris inside box, what's the best way to clean coils?
