Excursion AC problem
Old Aug 25, 2016 | 07:49 PM
procraftrob's Avatar
procraftrob
Hi
I'm trying to recharge my AC after repairing a hose. It held vacuum for 20 min without any losses. I continued to pull a vacuum for an hour or so. My problem is when trying recharge it, it took one 14 oz can no problem but with the next 14oz can it is no longer taking it in. Compressor is cycling on and off and air got a little cooler but no where near where it should be.
Any help is greatly appreciated
Old Aug 26, 2016 | 02:03 PM
projectSHO89's Avatar
projectSHO89
Be patient, it can take a LONG time for that procedure to draw in the refrigerant gas as it only sucks a little in each time the clutch engages. You can speed it up by raising the temperature of the can of refrigerant. A bucket of hot (100-120F) water to immerse the can in will do the job. As the refrigerant charge inside the sysgtem increases, the on-time for the clutch will gradually increase.
Old Aug 28, 2016 | 03:57 PM
william_04_x's Avatar
william_04_x
You're only introducing new refrigerant to the low side, correct?
I only ask because I had the rear suction line on mine repaired earlier this summer, and vac'ed/recharged myself. Took a full charge in less than 20 minutes using 12 Oz(IIRC) cans.
Old Aug 28, 2016 | 11:41 PM
procraftrob
Thanks for the help
Yes I was only adding to the low pressure side. I will definitely be more patient next time. Those are both valid points.
Really appreciate the input. will update when I attemped again
Old Aug 29, 2016 | 01:34 PM
projectSHO89
If he's using only one of the simple cans with a single hose, it can only be connected to the low side port.
Sk1nner
Jun 23, 2017 07:33 PM
majorgunho
Apr 18, 2017 10:44 PM
heebeha
Jun 26, 2015 11:17 AM
marks500
Jun 16, 2014 08:52 AM
VA250SD
May 12, 2012 11:58 AM
