CV swap again
Old Aug 31, 2016 | 10:16 PM
crazed87bronco's Avatar
crazed87bronco
What year jag independent front ends are good to use on the 65-66 frame for these swaps?
Old Aug 31, 2016 | 10:28 PM
James_Western_Canada's Avatar
Here is a write-up Matt did several years back on his straight axle '64, but the procedure is much the same on a Twin I Beam truck.....
Slick 60's ? View topic - -TECH- Jag XJ6 IFS into F100
Old Sep 1, 2016 | 05:49 AM
crazed87bronco
Are the straight axle frames the same as the twin I beam's as far as the width and engine crossmember area's? If you use the jag front end on the i beam trucks does the engine X member still need to removed like you would on a CV?
Carmax
13
Oct 17, 2018 12:02 AM
rgoodell
Jan 2, 2013 09:14 PM
dillenger1
Mar 3, 2011 02:04 PM
RynL88
Apr 20, 2009 07:48 PM
Jocaren
Mar 8, 2008 11:37 PM
