Lowering rearend
Old Aug 25, 2016 | 12:50 PM
bbyrnes1's Avatar
bbyrnes1
Lowering rearend
I'm wanting to lower the rearend of my 81. I know the options are doing a half flip or full flip of the front hanger, taking some leafs out, and flipping a leaf for free lowering. Which of these, or which combination, will get my rearend the lowest without having to notch the frame?
Old Aug 26, 2016 | 04:10 PM
Franklin2's Avatar
Franklin2
You can't change physics. When you lower the rearend any amount, you lessen the amount of up and down travel when it goes over bumps.
Go out there now, find the rubber bumpers, and measure from the rubber bumpers to where the rubber bumpers hit on the leaf spring blocks. That's the amount of travel the factory gave the truck.
If you don't haul anything in the bed, you probably can get away with lowering it a couple of inches and not hurt anything. If you lower it much more, you will probably be right against the rubber bumpers. When then you drive down the road, there is no travel in the suspension, so you will be like those guys who lower their Hondas onto the bumpstops and they look like bobble head dolls as they go down the road.
So you are hitting the rubber bumpstops, so you take them off. So that gives you more travel, but once in awhile you hit the frame. You decide you want it even lower, so when you do that you hit the frame over every little bump. That's when you have to notch the frame.
Old Aug 26, 2016 | 08:30 PM
bbyrnes1's Avatar
bbyrnes1
10-4. What I'm thinking I can get away with is taking out my bottom overload leaf and MAYBE flipping the small leaf upside down on top to flatten the pack out. This should avoid needing pinion angle shims I'm reckoning and keep a similar spring rate but not beat me to death.
Old Aug 27, 2016 | 07:16 AM
Franklin2's Avatar
Franklin2
Taking the bottom overload leaf out would probably work if you never use it. I have never flipped a leaf over. I would think a upside down leaf fighting with the other leafs would increase the spring rate some.
classicrat52
Jan 16, 2019 07:12 PM
Rezza56
Jul 9, 2018 10:20 PM
worm0479
Oct 8, 2012 10:26 PM
tgowers
May 18, 2006 07:38 AM
fishmanndotcom
Offroad & 4x4
15
Mar 29, 2005 12:20 AM
