Trailer connector-no brakes or turn signals
Hooked up to my trailer and I have running lights but no turn signals, brake lights, or trailer brakes. I pulled plugged in my other vehicle to the trailer and everything works fine.
My truck is a 2011 with the factory trailer brake control and pigtail connection. It worked fine last year.
I checked the connector with a test light and there is only power to the running lights. I then disconnected the plug at the back of the trailer connector and tested there and got the same results.
Are there particular fuses or relays I should look at?
thanks
thanks
Well the lights issue is taken care of. It was a blown fuse in the distribution box (fuse #73).
However my brake issue still remains. The brake actuator acts like it is giving the brakes a full "10". It shows on the trucks gauge panel and acts like the brakes are working fine. However there is no brake actuation that I can detect. I pulled the emergency cable and the trailer brakes locked up, so the trailer brakes are working up to that point.
Any ideas?
Any ideas?
Choke
1997-2006 Expedition & Navigator
07-14-2004 04:14 PM
