Old Newbie
As I am not much of a Internet whiz, please over look any protocol breeches and Screw ups.
I recently saved a 1969 F250 Crew Cab, short wheelbase, 4x4 from the local crusher and have been slowly rebuilding the 4x4, tranny, brakes, gas tank and lines, etc,etc, . I have begun to shift my attention to the body and have come across a problem no one seems to have a definite answer on. I am dealing with the usual cancer on the truck but over all it is not in bad shape except for the top, bottom and both sides.
Back to the question I need answered at this time. Is a 2x and a 4x radiator support for the 1969 f250 the same part. I have noticed in the LMC catalog that it does not list a difference. However other catalogs list it only for a 2x. \\
Thanks in Advance
Gafarmboy ( Just not that much of a boy anymore
1967/72 F100/350.
D3TZ-8146-C (replaced C8TZ-8146-K) .. Fan Shroud / Marked on upper left (drivers) side corner: C8TA-8146-S or D3TA-8146-DA / Reproduced by Carpenter.
1968/76 F100/350 360/390 with standard/xtra cooling & A/C radiators.
C7TZ-16138-B .. Radiator Support-Use with Super Cooling radiator that measures approx. 26 1/4" wide x 24 1/8" high / Obsolete
1967/72 F100/350.
C7TZ-8146-B .. Fan Shroud-Use with Super Cooling radiator / Marked on upper left corner: C7TA-8146-H or D2TA-8146-HA or D3TA-8146-JA / Reproduced by Carpenter.
1967 F100/350 352 / 1968/76 F100/350 360/390.
Hey, at least the front and back are okay, right
They are in excellent shape and they are missing....
To all who provided all the great information, Thank You Very Much. I now have a starting point to work from..
Gafarmboy
