Couple ??/
Whens service due , I read the manual and it looks like different uses different kms?
I havnt had truck 2 weeks yet and I have a little over 4000 kms on it.
Whats the B20 on the badge below the 6.7 mean?
Normal use. Every six months, or 12,000 kms. Severe use. Every six months or 8,000 kms. Something else to consider is engine hour count. Recommended oil change interval based on engine hour count is every 200 hours. Those are manufacturer recommendations. Fuel filter changes are recommended every other oil change. DEF refills are recommended at every service.
These trucks are B20 compatible meaning you can use up to 20% concentration of bio-diesel fuel, unlike the previous 6.0L/6.4L trucks which were only B5 compatible
B20 = Biodiesel at 20% bio to 80% regular diesel. You are certified to run up to the 20% biodiesel amount. Less to none is OK as well. Being in Canada, you might have a problem finding it and you can't really run it in winter because it gels faster than regular diesel. I do like running it when I can - which now is never because I moved to Alaska.
On Edit: Do what m-chan says... He is a ford diesel mechanic... I follow the book - although I do use a full syn 5w-40 as well... Ohh if you run Bio you are supposed to change the oil every 3k miles. I don't, so I just let the truck tell me or if I run a vehicle health report and I know I am getting close I do it early.
