Sponsored by: Real Truck
Thump while accelerating
Old Aug 21, 2016 | 07:33 PM
'99F250's Avatar
'99F250
So lately I have noticed that my 99 F-250 has a bit of a "bump" while accelerating. Think of it as accelerating with a trailer and something is loose on the hitch, making a sort of bump or thump. I talked to the guy at the parts store and he said to put it in neutral and wiggle the driveshaft up and down, side to side. When I did that it moved up and down, but not side to side, but I'm not sure if that's because it's just positioned that way or what. The wobble was coming from the slip yoke back by the rear diff. Is this something I should be concerned about? I priced a new driveshaft at about $360. Also, I have an ext. cab and short box, 1 piece driveshaft.
Here's a video (a very crappy video at that), not sure if it gets enough info through or not but hopefully you kinda get how much play is in there.
Old Aug 22, 2016 | 05:11 AM
redford's Avatar
redford
FTE Leadership Emeritus
Try putting a little grease in your slip joint.
Old Aug 22, 2016 | 07:58 AM
Diamnd1's Avatar
Diamnd1
Use hi temp grease. I used wheel bearing grease the first 2 times. Used hi temp last time and is good so far with about 10k miles.
Old Aug 22, 2016 | 08:32 AM
BandBFord's Avatar
BandBFord
It appears Ford recommends D2AZ-19590-A Teflon grease to lubricate the slip yoke with for most 98-04 F-series. TSB 04-1-6 covers this for 98-04 F150's.
Hope this helps,
Old Aug 22, 2016 | 04:56 PM
'99F250's Avatar
'99F250
Is there a special way to grease it, or just pull it off and grease 'er up good?
Old Aug 22, 2016 | 07:41 PM
Ginther's Avatar
Ginther
I followed LINK: THIS THREAD when I did the slip joint on my 2004. It was making the bonk sound/feel when taking off from a stop.
After grease... no more bonk!
Old Aug 22, 2016 | 08:45 PM
'99F250's Avatar
'99F250
Looks simple enough, I'll see if I have time to do it this weekend. I'm thinking of replacing the U-joint bearings as well, would it pay to? As of now they don't move or wiggle--yet.
Old Aug 23, 2016 | 07:07 AM
Ginther's Avatar
Ginther
Not sure what your mileage is... but just being 17+ years old might warrant new u-joints and maybe a carrier bearing (if you have one) just due to age.
Relatively easy DIY stuff too, parts should be common and easy to get, so shouldn't cost too much.
Old Aug 23, 2016 | 07:15 AM
'99F250's Avatar
'99F250
The truck has about 130k on it. So I just replace the whole U-joint altogether?
RenoHuskerDu
Dec 19, 2017 12:26 PM
Diamnd1
Feb 22, 2013 05:01 PM
moedaddy
2009 - 2014 F150
Aug 25, 2012 06:37 PM
jvwfd51
Oct 2, 2007 11:37 AM
wire4money
1983 - 2012 Ranger & B-Series
May 9, 2004 05:34 PM
