pink wire behind IPC
Old Aug 20, 2016 | 07:23 PM
champipple's Avatar
champipple
Gents, doing some tail light wiring and just happened to feel the pink (extremely hot) wire that runs from the ignition switch into the harness. any idea where it goes?
thanks in advance.
Old Aug 20, 2016 | 07:36 PM
FordF1004x4's Avatar
FordF1004x4
Looks like it goes to the resistor then to the + on the coil, and to the starter relay.
That is what it says on the 1958-1960 wiring poster I got. Hope its right and helps.
Old Aug 20, 2016 | 09:37 PM
champipple's Avatar
champipple
Thanks, much appreciated. i've determined that the wiring has been modified [train wreck] and the diagram i have is almost useless. combine that with my inexperience and someone should put a tent over this circus!
Old Aug 20, 2016 | 09:50 PM
FordF1004x4
I also have a big mess of wires. I got the chart in case some of it is right.
I am just going to add a whole new modern fuse panel in it.
Old Aug 20, 2016 | 10:12 PM
champipple's Avatar
champipple
will do the same, have any info on the panel and where to buy?
Old Aug 21, 2016 | 09:38 AM
Grinchman's Avatar
Grinchman
I am doing my wiring right now on my 57. I got my wire harness from ez wiring. It looks to be good quality and the price is right. The wires are marked every 5 inches. Also they have good tech support. ezwiring.com
Old Aug 21, 2016 | 10:11 AM
FordF1004x4
What Grinchman said is good. I saw one of these and they are pretty sweet. Like he said labels and such. It is probably the best option.
I am still looking at a few options. The old crap still "works" but I am working on other things first. It is also still hot as hell outside so this would be a winter project.
Old Aug 21, 2016 | 12:31 PM
champipple's Avatar
champipple
ha! yes, the heat just moved out of indy so things aren't like a wet wool blanket so i expect much progress today. thanks for the info gents!
Old Aug 22, 2016 | 07:29 AM
champipple's Avatar
champipple
Update: tail issue resolved, seems like previous owner canceled tail lights for turn signals. can't have all three with two wires. [he put the "J" in genius]. the ezwire kit is on order and will be a winter project. thanks for the suggestion.
the pink wire issue is still at large...
Old Aug 22, 2016 | 02:45 PM
MARC's Avatar
MARC
Might be brake light power switch. Check voltage thru pink wire with ground. If no voltage, jumper the two connections on brake light switch and check voltage on pink wire again. Will at least tell you if it is the brake light source power
Old Aug 23, 2016 | 09:23 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The pink wire issue is still at large.
COLF-12250-A .. Resistor Wire-Ignition Coil (Motorcraft DY-37) / Obsolete ~ Available NOS & from auto parts stores.
61.49" long / Color coded pink / 1.30-1.40 ohms resistance / #20 gauge wire.
1960/73 all FoMoCo vehicles.
jniolon
Apr 28, 2018 01:02 PM
Shopman
Aug 2, 2007 06:51 PM
dorkpunch
Jun 9, 2005 11:53 AM
lshort
Electrical Systems/Wiring
Apr 2, 2002 12:00 AM
