5r55s issue
Old Aug 20, 2016 | 07:02 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
5r55s issue
Couple of weeks back the wife started having tranny issues (05 explorer 4.0 AWD). OD light flashing, massive shift flare on the 1-2 shift, and overdrive seems to have disappeared.
Checked the codes and got the usual "incorrect gear ratio" codes (can't remember the numbers). All this pointed to a failure of the OD servo.
So... I ordered one of those servo repair kits and was going to install it today. The first line of the instructions says to check the OD band adjustment by torquing it to 120 inlbs and backing off two turns. Here's the issue...... the OD band won't torque. I can run the adjusting screw all the way down by hand.
I assume this means the overdrive band is broken and my kit won't fix anything. I also assume at this point I should be looking for a rebuild/reman.
I'm seeking conformation one way or the other. Any opinions? Any other options?
Thanks!
Old Aug 26, 2016 | 01:00 PM
jk080's Avatar
jk080
Transmission Rebuilder
If the band adjustment wont tighten then the band is most likely broken, I see this on a regular bases.
Old Aug 30, 2016 | 09:59 PM
cookie88's Avatar
cookie88
FTE Emeritus
Yep. Not being particularly strong with slush boxes I went and got an estimate to rebuild. $2600.
Yeah..... Rebuild kit at ~$300. I'll do it myself thank you very much.
Treacy
Jan 14, 2018 01:41 PM
Resendiz
Feb 17, 2017 04:58 PM
RVanPeeren
Sep 6, 2014 03:06 PM
F350Bandit
Nov 11, 2012 07:37 AM
ejzalesk
Jul 3, 2003 07:13 AM
