Cylinder head question
Old Aug 19, 2016 | 12:10 AM
Krose788's Avatar
Krose788
I have d3ve heads now and I came across some d9te heads.are they worth buying are they any better than the ones I have now? Thanks
Old Aug 19, 2016 | 11:47 AM
77460f150's Avatar
77460f150
I'd stick with the D3VE's. -Ed
Old Aug 19, 2016 | 03:36 PM
Jonnyuma's Avatar
Jonnyuma
Can you expand (expound) on that at all?
I'm sure much has been written regarding flow, chamber size, open vs closed chamber, port design, valve sizes, response(s) to basic porting, valve or spark shrouding, etc...but for us new guys maybe you could tell us why you think one is as good as the other and if there are some differences to be aware of. Knowledge is power...
That'd be like, totally cool.
Thanks,
JY
Old Aug 19, 2016 | 06:45 PM
matthewq4b's Avatar
matthewq4b
the D3VE heads are basically the same as your D9TE heads. The D3 heads were used up until 79-80, Ideally you should try to find a set of C8VE C9VE or D0VE heads.
The D0OE heads are the cobra jet heads. D2OE and the D3AE heads are the Police Interceptor heads similar to Cobra Jet.
Avoid the D2VE heads they had the largest combustion chamber and were fully open with no quench area and tend to detonate.
Hope this helps.
Old Aug 19, 2016 | 08:59 PM
Jonnyuma's Avatar
Jonnyuma
Absolutely.
Old Aug 19, 2016 | 11:52 PM
Krose788's Avatar
Krose788
Thanks man that's some good knowledge
Old Aug 21, 2016 | 11:49 AM
Krose788's Avatar
Krose788
What casting number was used for boss heads
Old Aug 21, 2016 | 12:39 PM
matthewq4b's Avatar
matthewq4b
429 Boss C9AE-A and D0AE-AA,
302 Boss C9ZE, D0ZE and D1ZE,
351 Boss D1AE-GA Same casting number as the Closed quench chamber 4v heads butmachined for push rod guide plates and valve spring seats/cups
banjopicker66
Mar 9, 2005 06:44 AM
tastyklair
Jul 13, 2004 07:55 PM
Ds7776
Sep 26, 2003 12:45 AM
stuperscout
Sep 8, 2003 06:12 AM
mamayek
Oct 18, 2001 10:24 PM
