Best Source for Refurbished CPUs
Old Aug 18, 2016 | 08:19 AM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
I don't need one yet (thank Yeezus) but some point down the road, I have little doubt that something in my old-as-hell computer will give out. When it does, I want to find the BEST replacement. I've heard horror stories about the regular auto parts stores CPUs (Cardone, etc) and I don't want to go that route. So, where is the best place to order these EEC-IV CPUs?
Old Aug 18, 2016 | 10:41 AM
rla2005's Avatar
rla2005
Standard Motor Products used to the best refurbished PCM vendor I dealt with. I am not certain they are still remanufacturing them. They actually test them instead of sticking a pretty label on it. You may find a retailer with stock.
Another option is to source a used PCM then send it here: ECU REPAIR NOW
Old Aug 18, 2016 | 10:33 PM
PRIMERED79 SHORT BED's Avatar
What are the signs of a bad ecm?
Old Aug 19, 2016 | 07:51 AM
rla2005's Avatar
rla2005
Continuously running fuel pump(s), multiple codes, poor running, no start, intermittent stumble and the list goes on.
Old Aug 19, 2016 | 10:54 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Best thing you can do is open up the case and look for leaking capacitors. It's easy enough to do and then you can address the issue before it might leave you stranded.
Thumper19
16
Mar 19, 2012 07:28 PM
Wiredoge4
Jan 13, 2012 10:53 PM
cb160d
Apr 26, 2010 09:59 PM
moonley
Aug 26, 2008 07:55 PM
