starter problem 83 F100 w C6
We swapped the 3 sp manual on our 83 F100 for a C6. Two rebuilt starters have hung up engaged. One shorted out before I could disconnect the battery and the 2nd had 2 chipped teeth and it burred the flexplate.
I've ordered a new flexplate but I wonder if the 4.9 to C6 needs a full spacer plate (? I don;t know if that's the right name) or just a partial plate covering the lower part.
I suspect the starter gear is not engaging the flexplate deep enough although I don't know if 1/16 of an inch from the spacer would make much difference.
Any help from the forum would be greatly appreciated.
Don't know. What starter are you using? Look for something missing or the wrong part. The starter should bolt up in 5 minutes and you can move on to bigger and better things, it should not be giving you all these problems.
The new flexplate, starter and solenoid didn't fix the problem. I found a starter repair shop that didn't try to rip me off. They said (from experience) that the problem was electrical and I needed to find a solenoid with copper contacts not the Chinese products. I paid about $ 10 more for a Standard solenoid and haven't had the problem since.
VanBourne
06-16-2014 10:45 PM
Relics
17
12-29-2009 10:26 PM
barnstormer
11-13-2005 11:38 PM
JSWF100
05-02-2000 06:43 PM
