C6 Flexplate
Old Oct 24, 2005 | 10:54 PM
barnstormer's Avatar
barnstormer
C6 Flexplate
I have a 79 302 2wd. I took out the C4 and put in a C6 which was out of a mid 80's van(I think). I kept my flex plate.
I am having problems with my starter. The flexplate teeth are hitting the starter teeth in the center, but only about 1/16" .Once the tips of the starter gear are gone, it will not turn the motor.
I was told that on the flex plate the C4 has 157 teeth and the C6 has 164.
I compared the two at the auto parts store and the only difference I could see was that the C6 maodel was shifted a little more toward the tranny. The diameter and teeth appeared the same.
I compared various starters and could not tell a difference in the nose.
I know that some type of an offset gear starter was made. Could that be the problem?
Old Oct 25, 2005 | 11:32 AM
loudfords's Avatar
loudfords
C4 and C6 flexplates are different. I would suggest getting a C6 flexplate from the boneyard. (Or if you have the $$, get a new one.)
Old Nov 13, 2005 | 11:38 PM
barnstormer
I pulled the flex plate, it was 164 tooth. I replaced it anyway, and also replaced the starter gear. Still the starter gear is barely engaging the ring gear teeth. I appears that I need a larger diameter starter gear. Any ideas?
backyardbikes
Jul 5, 2018 11:23 PM
Rayzors250
Jan 20, 2012 07:05 PM
ginch66
Nov 6, 2011 01:41 AM
Blue50F-1
Jul 20, 2009 07:14 PM
