Starting problem
Old Aug 16, 2016 | 10:35 PM
dvlsmstr's Avatar
dvlsmstr
Starting problem
So my sister has a 2000 Ranger 2.5L. I put in a new starter today for her today, and the second I re attach the battery terminal it turns over but wont fire. ?
Old Aug 17, 2016 | 06:36 PM
spooktn's Avatar
spooktn
Was just wondering if it is getting fuel and spark both,,, you only need 3 things to fire a cylinder ,,,, air,,, fuel and spark .. Which are you missing ??? Most likely fuel or spark,,,you can try giving the Throttle Body a shot (spray) of starting fluid and if it runs a second and quits then it is a fuel problem,, if it still does not start it is a spark problem... when you say the second i attach the battery terminal it turns over but wont fire,,, I assume you mean when you turn the key,,, and not fire up,,, or do you mean wont fire the plugs ??? There is a fuse under the hood that applies voltage to the coil packs..and also a fuse for the anti theft system ,,, the anti theft system can stop fuel or spark or both depending on year and model...here is a wiring link that might help you out ......Search Wiring Diagrams
Old Aug 17, 2016 | 06:50 PM
cracked block's Avatar
cracked block
Sounds like your starter solenoid is hung up. Give it a rap with a hammer and see if that solves the problem.
Old Aug 17, 2016 | 07:21 PM
spooktn's Avatar
spooktn
Oh maybe I miss understood if the starter is turning the engine over just by hooking the cable up then I agree with cracked block,,, your starter solenoid is stuck or sticking and sometimes a good whack will unstick it,,,sometimes it wont
Old Aug 18, 2016 | 06:40 AM
02FX4Dude's Avatar
02FX4Dude
Pull the starter relay, if the starter still runs it's the solenoid. If not it could be the relay or starting circuit.
benbuilder
35
Mar 10, 2018 05:30 PM
Ocelotl
Feb 22, 2018 05:31 PM
moritz1024
1978 - 1996 Big Bronco
Jul 23, 2012 07:54 AM
Azhiaziam
Jan 13, 2008 08:12 AM
900rider
19
Jun 26, 2005 03:22 AM
