1978 - 1996 Big Bronco
fpr???
Old Jul 22, 2012 | 08:38 PM
moritz1024's Avatar
moritz1024
Arrow fpr???
hey guys my 89 with the 5.0 has been sitting for months. among other problems now i cannot get it to start. first the inlinefuel pump was seized and of course i replaced the filter i have spark all around but just cannot get her to turn over. i know it has a rather large vaccum leak as well due to the fact that the intake needs to be milled. what i really need to know is there a way to manually test the fuel pressure regulator with vaccum and air? i already took it off the fuel rails and have it in my hands
Old Jul 22, 2012 | 09:11 PM
ctubutis's Avatar
ctubutis
Originally Posted by moritz1024
...i cannot get it to start. first the inlinefuel pump was seized and of course i replaced the filter i have spark all around but just cannot get her to turn over.....
This is confusing - what does spark & fuel have to do with turning over? Turning over involves the battery, starter solenoid and starter motor and has nothing to do with fuel & spark.
Or, are you trying to say the engine turns but won't start? If that is your intention, you would help yourself by providing clear information up front, thank you.
Old Jul 22, 2012 | 09:17 PM
moritz1024's Avatar
moritz1024
stop busting my chops. can u tell me how to test the fpr or not?
Old Jul 23, 2012 | 06:30 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
This type of response will get your chops busted, if a MOD busts yours you will know it !
Around FTE it is always good to initially define your problems with complete and understanding communications.
Like clear sentences....and of course NEVER name calling of any type!
YOU have been on the site long enough to know how to interact with other members....now lets get on... with getting you truck running.
Old Jul 23, 2012 | 07:54 AM
Conanski's Avatar
Conanski
Probably.. but you would need to build a special jig to put pressure behind it and some way of applying the correct amount of vacuum and then have gauges to measure the change in pressure resulting from various vacuum levels. Or you could just put it back on the truck and put a fuel pressure gauge on the fuel rail and test the whole fuel system in one shot. For the most part as long as you don't get fuel out the vacuum nipple then there's probably nothing wrong with the regulator, the pumps and in your case the dual function resovoir are the usual sources of low fuel pressure.
RamdyZavage
Aug 9, 2017 11:13 PM
dvlsmstr
1983 - 2012 Ranger & B-Series
Aug 18, 2016 06:40 AM
BBUCSFAN
1997 - 2003 F150
Sep 14, 2012 11:03 AM
sexybluelady
Feb 25, 2011 03:06 PM
900rider
19
Jun 26, 2005 03:22 AM
