Charlee version 2.0
Old Sep 27, 2016 | 02:31 PM
  #31
knottyrope's Avatar
knottyrope
Originally Posted by dclack
Ugly! Maybe I should double check mine.
I found a loose one after doing my inj orings
Old Sep 27, 2016 | 03:34 PM
  #32
Jarrett Campbell's Avatar
Jarrett Campbell
Ds looks way better.
Ugh this sucks..... I need to get them rebuilt don't I?
Old Sep 27, 2016 | 03:39 PM
  #33
knottyrope's Avatar
knottyrope
once they over heat there is no telling what damage has been done inside
could be puking fuel or not squirting enough
also heat treated parts can be weak and break off
Old Sep 27, 2016 | 04:05 PM
  #34
dclack's Avatar
dclack
I'd definitely give Jim a call and send him some pictures.
Old Sep 27, 2016 | 04:15 PM
  #35
Jarrett Campbell
Yeah I figured. I'll give him a call tomorrow.
Operation "motor swap/ic install/turbo rebuild/injector refresh/sas rsk" engage!
Old Sep 27, 2016 | 04:21 PM
  #36
dclack's Avatar
dclack
Sounds familiar. For me it was the clutch that drove all the upgrades.
Old Sep 27, 2016 | 04:23 PM
  #37
knottyrope's Avatar
knottyrope
hope none of the cups were damaged
Old Sep 27, 2016 | 05:10 PM
  #38
Jarrett Campbell
I'm actually worried about that myself. The coolant is about an inch or two low. No water on dipstick yet
Old Sep 27, 2016 | 05:12 PM
  #39
z31freakify's Avatar
z31freakify
If it were cups you will have diesel in coolant not the other way around.
Old Sep 27, 2016 | 05:16 PM
  #40
Jarrett Campbell
...so if that were the case, my coolant level would have gone up not down. I guess I have a coolant leak I haven't found
Old Sep 27, 2016 | 10:14 PM
  #41
nateairman's Avatar
nateairman
Wow!
That has me wantin to pull my valve covers as soon as I get home from this trip and have a look.
Did your fuel filter give any indication that you had loose injectors?
Old Sep 28, 2016 | 09:10 AM
  #42
fordman67's Avatar
fordman67
Originally Posted by nateairman
Wow!
Are we not using a torque wrench on these!?;?!? I'm not worried because I know they are to spec...
Old Sep 28, 2016 | 09:41 AM
  #43
Jarrett Campbell
I didn't own a torque wrench at the time. I should have popped the vcs off to verify when it finally came in but I didn't and now here I am lol
I didn't cut my fuel filter open to check it when I changed it... But even if I had, it would have been pretty filthy from the front tank before I cleaned it.
Old Sep 28, 2016 | 09:50 AM
  #44
knottyrope's Avatar
knottyrope
That's a hard expensive mistake to admit.
Pressurize the coolant system while you have injectors out and check for coolant weeping in the cups
Old Sep 28, 2016 | 10:47 AM
  #45
Jarrett Campbell
Good call. I'll do that.
And I will always admit my mistakes. No sense blaming it on anyone else and giving them a bad reputation.
But everyone who is reading this please know... Even if you think it is tight enough, if you didn't use a torque wrench, you don't actually know and you could be getting some injectors with 10k miles rebuilt... again.
