400 C6 torque converter nut help.
Old Aug 16, 2016 | 10:26 AM
maribou912's Avatar
maribou912
Hello everyone. I've got a 400 mating to a C6. I pulled the motor about three years ago and I lost the nuts that connect the torque converter to the flexplate. Will a grade 8 nut do the trick? And do I need to put a washer behind it?
Thank you in advance for your help.
Old Aug 16, 2016 | 10:35 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Those are torque retaining nuts. A standard grade 8 might loosen. Any auto parts store would have the right nuts for peanuts.
Old Aug 16, 2016 | 10:39 AM
maribou912's Avatar
maribou912
Thanks mark.
Old Aug 16, 2016 | 11:48 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No.
378941-S440 (replaced 378941-S7) .. 3/8" -24 Torque Converter to Flexplate LOCK Nut / Available from Ford & auto parts stores.
Same: C4/C6/AOD/FX/MX/FMX Cruise-O-Matic / No washer required.
Old Aug 16, 2016 | 03:21 PM
DB429SCJ's Avatar
DB429SCJ
Check with your local transmission shop.
herbiemin
May 9, 2015 01:29 PM
704 dentside man
WTB - Parts & other
Aug 5, 2013 10:48 AM
pboffroad
Nov 5, 2012 09:47 AM
7283-F250
May 8, 2007 08:14 AM
alankirby
Mar 27, 2006 05:48 AM
