Wanting upgrade trucks, need help
Old Aug 15, 2016 | 04:18 PM
msfprobass's Avatar
msfprobass
Hey all, I've always been a f-150, Bronco kinda guy, but am really wanting to upgrade. This will probably happen next year, just starting my search. What I'm wanting is the 2008+ body and interior design. Manual transmission is an ABSOLUTE MUST, so I know that basically limits me to the 08-10. I know this has probably been beat to death but I really want to know some info.
1) If I find the right truck and the 6.4 powerstroke gives problems, does anyone make an adapter to fit the manual in the 08-10 trucks to the 6.7 powerstroke?
2) If so, couldn't one just change the transmission on the 11+ trucks to include the manual on the newer
3) would the manual from the 08-10 trucks handle the 6.7 powerstroke?
4)If so, and I start looking at the local swap shops and/or junkyards, what is the transmission called( ex: c6, e40d, zf-6, etc)
5) did Ford use the same manual in these years for the 6.4 and the 5.4 or 6.2?
Old Aug 15, 2016 | 11:38 PM
85e150's Avatar
85e150
1) Adapter. Couldn't find one. As OEM, the bell pattern is the same as the Mod engines and 6.0/6.4. So a MT from one of those would bolt up after you have a flywheel and clutch made for it.
2) Change newer truck to MT. Sure, again, you will have to make some of your own parts and reprogram the computer.
3) MT handle the 6.7--The ZF 6 was rated at 520 ft/lb, so it would last a short time.
4) ZF6
5) ZF 6 and 5 for those earlier trucks.
You could make an adapter for a NV5600, but I think that is rated lower than the 6.7 output as well.
What you are really doing in most cases here is downgrading the truck. I like the mt as much as anyone, but the fact is the new automatics have them beat. If you want a MT truck, buy an older truck. It is much easier IMO to rebuild the the "soft" parts of the truck around a drivetrain than to reengineer a modern computer controlled drivetrain.
Old Aug 16, 2016 | 11:23 AM
msfprobass's Avatar
msfprobass
Thanks for the info 85e150six4mtod!
Menghi08LT
6.2L V8
Aug 27, 2024 07:19 AM
msfprobass
Aug 16, 2016 06:57 PM
msfprobass
Aftermarket Products
Aug 15, 2016 04:20 PM
msfprobass
6.7L Power Stroke Diesel
Aug 15, 2016 04:16 PM
Notpilbrisk
Feb 26, 2006 01:42 PM
