Transmission
Old Dec 15, 2015 | 11:40 PM
Cody LaFata's Avatar
Cody LaFata
Transmission
Does anyone know or know where to find the model number of the transmission i have in my 1977 f250? Its the 4 speed granny low, truck is 4x4 and has a 351/400m
Old Dec 15, 2015 | 11:47 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
(New process) NP435 = aluminumtop cover w/8 bolts
T-18 = cast iron top cover w/6 bolts WarrantyPlate TRANS code:A=NP435 (N-1965 only) /F=Warner T-18 /P=F350 Warner T-19.
Warner shift lever retainer cap (8MTH-7220) threads on/off.
NP435 shift lever retainer cap (B8T-7220-D)has two notches, is retained to shift tower by two pins.
To remove this cap, it must be pressed down and held down while turning it counter clock wise to remove it. (Its spring loaded and twists into place, we removed one and it was a 2 person job. Put the trans into 2nd, 4th, or reverse, then one person holds the cap and applies pressure, twisting in a counter clockwise direction. The other person hits it from the top with a hammer to get the cap to go in below the two clips that hold it in.) People unaware use pliers or channel locks to remove it, which tears out the pins.
Originally NP435: Reverse-down towards the seat while Warner T-18: Reverse-uptowards the dash.
The reverse shift pattern was changed circa 1973, but I can't recall forwhich of these 4 speeds. (I believe it the NP435)
Note:There's another 4 speed: RUG SR-OD Single Rail 4 Speed Overdrive introducedin 1978 F100/150 300/302, TRANS codeB
Old Dec 15, 2015 | 11:50 PM
77&79F250's Avatar
77&79F250
Also just decoder your vin and it should tell your what the truck at least came with from the factory.
wpnaes
S. California Chapter
57
Apr 28, 2021 02:33 PM
wa-sleeper
Jul 8, 2018 12:01 AM
chukar
Aug 13, 2016 06:53 PM
Chris Popanz
Nov 26, 2015 03:09 PM
Zip
British Columbia
Sep 30, 2008 02:10 AM
