I am considering the Goosebox for my 17 SD. I always use B&W's turnover ball gooseneck hitch and the Goosebox would make my life easy.
My questions:
1. If you have it and a short bed truck what is the max turning angle that you can get? What RV do you get that angle with?
2. I see that B&W makes a 4" extension for the gooseneck ball which would sit the RV farther from the truck and allow farther turns. Anyone running this?
3. My current B&W Patriot gives me height adjustability as does the pin box. With the Goosebox I will only be able to adjust the pin box. Foresee any troubles here? The 17 SD has bed rails 1" higher than the previous models.
