Power Distribution Box
Old Aug 13, 2016 | 07:59 AM
boomcyl's Avatar
boomcyl
99' F250...I have traces a short to the PD box....I pulled, one by one, every fuse and relay and the short remained..what's next?
copied from 2010 post but have same prpolem.
2000 Lariat F250 7.3 2wd auto.
i unhooked starter and alt fuse links at bat and sol and left fuse link to PDB hooked . took off neg bat cable connected amp meter in series about 2 amp
draw. pulled every fuse and relay still amp draw. doors arent open keys out when i take fused link wire to PDB off no amp draw so no short inbetween i guess. also hooked up 1 ohm 10 watt resistor in place of DMM getting about 250 mv.
Old Aug 13, 2016 | 04:18 PM
retiredsparky's Avatar
retiredsparky
OK, you installed a 1 ohm resistor between the neg battery terminal and the cable. From your post you measured 250 millivolt across the resistor.
E=I*R so you have .25 amp current through that resistor. That is completely reasonable for keep alive current for the electronics.
Why is there a problem with this?
Old Aug 14, 2016 | 06:34 AM
boomcyl's Avatar
boomcyl
i have to buy fuses for DMM but, was getting around 2.5 amps? is this norrmal? truck would not start with 2 new batts after 2 days. son just bought this truck. the person with the resistor sugestion said 35-45 mv was normal.
will put it back together and see what happens. thanks for answer
Old Aug 14, 2016 | 09:31 AM
pirschwagon's Avatar
pirschwagon
I have to say, I am somewhat confused.
You are tracing a Short to Ground? If so, there would be a blown fuse that would identify the circuit. There is also another fuse panel and GEM under the Dash. Ps: The Gem should sleep after xx minutes. You may have to wait.
copied from 2010 post but have same problem.
"2000 Lariat F250 7.3 2wd auto: I unhooked starter and alt fuse links at bat and sol and left fuse link to PDB hooked . took off (-) bat cable connected amp meter in series about 2 amp draw."
Or, are you saying you have a parasitic draw as described above?
pulled every fuse and relay still amp draw. doors aren't open keys out when I take fused link wire to PDB off no amp draw so no short in between I guess.
Is this what you did? Or, is it from the other post you referenced?
Is this what you did? Or, is it from the other post you referenced? up to .750mv is acceptable. A .250mv is average for a system sleep mode. But, Why the 10w resistor?
Or, am I just totally lost here?
Old Aug 14, 2016 | 10:36 AM
boomcyl's Avatar
boomcyl
?10 watt resistor from youtube parasitic draw how to.
?i pulled "all fuses and relays" with meter connected . no change.
?batteries disconnected over night
im the lost one seeing i did not know that .750 mv was acceptable but new batts did run down after 2 days and would not start truck. thats why i started this. now put back together again and will wait. son does not need truck yet, still other work to do on it.
thanks for the replys wiil follow up post
Old Aug 17, 2016 | 06:32 AM
boomcyl's Avatar
boomcyl
well as my follow up the truck started. all i did was move wires around and clean the batt posts. oh and blow my DMM amp fuses.
i also learned some and i thank you for the information and responce
Thanks
Rusty_S
Electrical Systems/Wiring
Feb 20, 2014 08:36 PM
RoyalFord
1997 - 2003 F150
Jan 15, 2012 11:38 AM
kawa
Oct 13, 2007 01:43 PM
hatchet
Mar 23, 2007 10:26 PM
four-sixty-power
May 8, 2005 03:26 AM
