9" rear end
Old Aug 12, 2016 | 03:59 PM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
9" rear end
We'll I continue to move along on my frame and am now in the process of removing the DANA & installing a 9" rearend. The original U Bolts wrap around the 2" spring and through the mount on the DANA but the 9" is larger around (3") than the DANA. 57 and newer springs are wider and therefore their lower mount leaves the U Bolts away from the sides of the springs.
Original lower mount.
Rearend & 3rd member are cleaned and POR 15ed. Backing plates & springs are out being sand blasted. I know many have made this conversion but I can't find the answer for my Axle/Shock mount.
Sure could use some help on this problem because that's pretty much the last of my chassis/frame issues.
Old Aug 12, 2016 | 07:25 PM
merten's Avatar
merten
You can use the plates from an F250 they have the 3" tubes.
Old Aug 12, 2016 | 09:43 PM
bjmayberry2
How wide are the 250s springs? I thought I saw that they were wider than 2".
Old Aug 12, 2016 | 09:57 PM
merten's Avatar
merten
2 3/16 - 2 1/4
Old Aug 12, 2016 | 10:19 PM
bjmayberry2
I was told by our local spring manufacture that the U Bolts need to be tight against the springs to keep from breaking the center bolts.
Old Aug 12, 2016 | 10:22 PM
Tedster9's Avatar
Tedster9
Have read the same thing. That's why Retorques after 500 or 1000 miles. Loose u-bolts can mean broken springs too.
http://www.suspensionspecialists.com/tech0004.html
Old Aug 15, 2016 | 05:42 PM
bjmayberry2
Found what I need but only one in a parts stash. It has TAAK5796A stamped in it.
Looks like this.
TAAK5796A
Can Anybody help me figure out what it's from?
Old Aug 16, 2016 | 07:34 AM
1950FordF1's Avatar
1950FordF1
Lower spring plate
Here is a shot of the lower plates from a 1963 F-100 9" axle. No numbers but will give you an idea of anther style to BOL for.
If you need the lower plates with the shock mount another FTE member may be able to help with a year range. The 63' axle has them welded to the housing.
Update: I did a search on ebay: http://www.ebay.com/itm/1964-Ford-F-...xWFYkh&vxp=mtr
Old Aug 16, 2016 | 09:38 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Look like this.
TAAK5796A
It looks like a GM Sierra-class piece. I used them on my 9" conversion. BUT if you look closely, hold it up against an axle tube, the holes aren't "square" pattern because the springs on the GM are not perfectly parallel.
The TAAK number sounds like Ford tho. The GM pieces are easily several times stronger/stiffer than the F150/250 pieces I found at the boneyards.
Old Aug 16, 2016 | 09:48 AM
drptop70ss's Avatar
drptop70ss
If your springs are 2 1/2" wide I used dakota plates on my F1 and welded on the original F1 shock mount. 3" axle tubes on my GM 10 bolt rear.
Old Aug 16, 2016 | 10:36 AM
bjmayberry2
Here's what the mount looks like with the shock mount. I'm sure it's off an old Ford truck but not sure of the year.
This uses Square topped U Bolts that go across the Leafsprings, past the axle and bolt from under the mount (side shown in the picture.
Old Aug 16, 2016 | 10:44 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
5796 is the Ford basic part number for a rear spring seat cap, but there's no TAAK-5796-A listed in the 1948/56 Ford truck parts catalog (see pic below).
I also looked in the 1953 Ford/Mercury of Canada truck parts catalog, 1956/57 Ford truck parts catalog, 1957/63 Ford truck parts catalog: Not listed.
Old Aug 16, 2016 | 10:46 AM
bjmayberry2
NumberDummy
I'm pretty sure they're from a truck newer than 56 as the 56's didn't have 9" rearends yet.
Old Aug 16, 2016 | 11:02 AM
NumberDummy
NumberDummy
TAAA/TAAK part number prefixes were introduced in 1953, used thru 1956.
5796: Pic-column right = 1957/63 truck parts catalog does not list TAAA or TAAK prefixes for F100 2WD or 1959/63 F100 4WD
1959/67 F100's with Limited Slip came with Dana 44's. 1963/66: Dana 60.2 with Limited Slip was optional / 1966/67: Dana 60.3 with Limited Slip was optional.
1957/67 F100 2WD rear springs interchange (type of rear axle makes no difference): 2 1/4" wide ~ 24" > > eye bolt < < 28"
Old Aug 16, 2016 | 01:04 PM
bjmayberry2
Bill,
Thanks for the info. Could have sworn I took it off the truck I robbed the 9" from. But that was over 35 years ago
gtotiger65
Aug 4, 2015 08:19 AM
90fordguyohio
23
Apr 1, 2010 05:21 PM
eclectix
Offroad & 4x4
Mar 20, 2006 02:59 PM
piperig78
Offroad & 4x4
Mar 29, 2005 11:27 PM
GreatNorthWoods
Oct 2, 2002 08:06 PM
