97 7.3 no start
Old Aug 14, 2016 | 12:19 PM
charecter1's Avatar
charecter1
Originally Posted by madpogue
How was the kill switch wired? Was a wire leading to that fuse cut in order to wire in the kill switch in series?
It looked like it was just a red wire from the kill switch connected to fuse #8. It didn't look like the wire was connected to anything other than the fuse and the switch.
Old Aug 14, 2016 | 03:01 PM
madpogue's Avatar
madpogue
Where did the other wire on the kill switch go? Unless it interrupted/opened a circuit somewhere, that kill switch wasn't a kill switch.
Old Aug 14, 2016 | 03:41 PM
charecter1's Avatar
charecter1
Where did the other wire on the kill switch go? Unless it interrupted/opened a circuit somewhere, that kill switch waysn't a kill switch.
I have no idea, it was kind of butchered but I'll have to pull it out today and figure it out and let you know
Old Aug 15, 2016 | 07:05 PM
charecter1's Avatar
charecter1
So I took the kill switch out and it didn't make a difference. Then I wanted to trace the wires from the idm and the fuse box so I lifted up the fuse box and looked under it and I didn't see any bad wires. So I put it back together and tried to start the truck again, and it's alive but the confusing thing is that it started with the fuse that was supposedly blown. So now I'm confused
Old Aug 15, 2016 | 07:17 PM
z31freakify's Avatar
z31freakify
I looks like the problem has something to do with the kill switch.
Old Aug 15, 2016 | 07:18 PM
charecter1's Avatar
charecter1
But I took it out and it still wouldn't start. It wasn't till after messing with the wires that it started
Old Aug 16, 2016 | 08:51 AM
farmert's Avatar
farmert
Take a look at the base where the supposedly blown fuse presses into, to make sure the base is making contact with the fuse blades. My son spent 2 days trying to figure out why his early 99 Superduty quit on him. What he finally found was that the fuse base and become spread open, and was not making contact with the blades of the fuse, on the load side of the fuse.
Old Aug 16, 2016 | 01:07 PM
charecter1's Avatar
charecter1
I never thought to check that, I'll do that later today after work. It didn't start again this morning and all I did was wiggle the wires under the fuse box, and bam!
Old Aug 16, 2016 | 03:19 PM
madpogue's Avatar
madpogue
That kill switch HAD to have OPENED the circuit somewhere; otherwise it wouldn't have worked as a kill switch. My guess is that they somehow tied it directly to that terminal in the fuse box that farmert describes above, and they might well have damaged it in the process, or dislocated it or something. So +1; inspect those base terminals. Bright light and magnifying glass might help.
sammie616
Dec 28, 2012 09:50 AM
james.jefferson
Jan 14, 2012 11:33 AM
twistedcherokee
Jun 9, 2010 06:21 PM
jgilrfr
Oct 12, 2009 07:05 PM
jerryd
Dec 2, 2004 10:18 PM
