Okay folks, here is a tough one. I am putting an aftermarket pulse sender into my C4 tranny (long story). Bottom line is it does not have a gear in the tail unit at this time. How many teeth do you think I should get for the plastic speedometer gear? I will be using a adjustable speedometer.
No, there is a worm gear on the output shaft and the plastic speedometer gear meshes with it when the unit is inserted into the hole on the tail shaft housing. Thanks for the help.
