Back up light not working
Old Aug 10, 2016 | 10:16 PM
1972fordhighboy2's Avatar
1972fordhighboy2
Hi there I own a1985 f250 4X4 4 speed.My back up lights don't work. I'm trying to find the wire that by the transmission. Where exactly is it? How does it look like?
Old Aug 11, 2016 | 06:28 AM
FuzzFace2's Avatar
FuzzFace2
What 4 sp trany do you have?
The wire should come from the left side (when sitting in the drivers seat) of the trany to the frame and plug into the main rear harness. That is how it was on both of my 81 trucks.
Dave ----
Old Aug 11, 2016 | 08:55 AM
1986F150six's Avatar
1986F150six
Have you verified that both bulbs are not burned out? What often happens is that one bulb will burn-out and it is not noticed. When the second bulb burns out, it is noticed. It is not uncommon to remove what may have been the original bulb(s) and find a dark yellowish paste on the base. This is the original dielectric grease used by the factory. With a soft cloth, remove as much of this from the socket as possible and replace the bulb. If you have dielectric grease, put a small amount on the base of the bulb to protect the electrical contacts.
Old Aug 11, 2016 | 09:51 AM
ctubutis's Avatar
ctubutis
There is also a point where two harnesses connect where dirty/bad connections can cause problems - LH rear corner, where the harness extending across the rear connects with the harness running the length of the truck.
Also, user-added trailer hitch wiring causes problems.
My BW T18 has the switch on the top-rear of the transmission IIRC.
Old Aug 11, 2016 | 06:16 PM
1972fordhighboy2
Dave ----
could I see how it looks like
xjpilot
29
Apr 2, 2017 06:46 PM
Bob 79 supercab
Electrical Systems/Wiring
Nov 9, 2013 07:31 AM
jfarcas
Jul 13, 2006 09:54 AM
Douglas Walker
Mar 20, 2005 05:37 PM
eehoepp
Aerostar
Mar 16, 2005 04:43 PM
