Rear trailer camera....Hard Wired???
Old Aug 10, 2016 | 05:50 AM
  #31
archerseven's Avatar
archerseven
Originally Posted by Rasalas
To power any device constantly on a trailer you could always add an always on circuit through the 7 pin trailer connector. The no 4 pin is a hot lead used to charge batteries on trailers and can also be used to run accessories. It would be a simple task to add an additional circuit to the trailer to run your "wireless" cameras. If the trailer is equipped with electric trailer brakes with an onboard battery for emergency breakaway it would be a simple tap to the battery. It is kept charged through that no.4 pin.
Man the plug side of that diagram is backwards, they're showing the back side of the plug where you would wire it in, so it should match the female side on the truck.
I notice odd things.
Old Aug 10, 2016 | 09:29 AM
  #32
Rasalas's Avatar
Rasalas
Looks like the plug side but I think it is the back of the truck side connector. The inside portion or this style connector both look very similar. It slides into the housing and is held in place by a set screw. Here is the other images which show the plug end.
Also note that this standard is for the flat blade connectors. The round pin type connector is very different. It is recommended that one diagram the vehicle plug with the aid of a test light to be sure everything is where it should be. Because of working backwards on one side of the connector it is easy to have the turn signals reversed or the markers blinking, or, well you get the idea. It is also good to keep the connector wiring diagrams in the owners manual or other accessible place for that jack knife turn that hooks the trailer wire on the frame and pulls the wires out of the connector. Never happens to any of us, right?
Old Aug 10, 2016 | 02:21 PM
  #33
KBMWRS's Avatar
KBMWRS
Wow, my first FTE post and it seems I'm not the only one concerned. That and I don't even own a SD yet.
Well my plan was to use the rear facing trailer camera not only for reverse but also on all the time driving...so I know what's back there.
I'm planning on a 25' Airstream so I think the power and transmitting concerns would be moot.
Since some of you know what the manual states concerning this I know the camera offered would not be what I wanted.
As for the wired versus transmitting camera, well I just thought FORD would have offered the latest technology. The cable strung across the length of any trailer seems old tech.
Some have legit comments about how to power and lay the cable but doing such to a Airstream ain't gonna happen.
RV wireless cameras are on the market and I'll be going with that. Its just that I thought I could do without another screen w/power wires in the cab.
Thanks all for the lesson in rear cameras. I'll be reading/lurking to learn more about the F-250.
Old Aug 10, 2016 | 02:28 PM
  #34
archerseven
Maaayyybe. It's confusing, where there should be a locator key there isn't, and instead there's a cutout (which I've seen on the plugs, but never an equivalent on the sockets) on the bottom.
Haven't seen one of those in ages.
It's also printed on the cover, which is nice. Of the many many awful things I've done and seen done to trailer plugs, I've never caught them on the trailer and snapped the socket off.... normally snow is what gets the truck-side of the connector for me.
Edit: Re-read. I've never pulled the wires free by snagging them on the trailer, either, though.
Old Aug 17, 2016 | 04:29 PM
  #35
1634Joe's Avatar
1634Joe
This is information I got from ford chat . The Customer-placed Trailer Camera wiring harness is 32ft. long.I sure hope they sell a extended harness because my trailer is 35' long. If anyone has any information on this let us know
Old Aug 17, 2016 | 04:43 PM
  #36
gotroxs's Avatar
gotroxs
I am pretty surprised at the length. I know the BLIS spot is around the same length and I can understand that due to technical limits. But I really hope they have a longer wiring harness that doesn't cost a few hundred dollars. My 5th wheel is 43 feet long and if I want it at the top of the trailer I will need another 10 feet on top of that.
Old Aug 17, 2016 | 04:54 PM
  #37
1634Joe's Avatar
1634Joe
Yes I agree my trailer is 35 ' so by the time you plug it in on the truck I'm going to be short as well . That was $700 that I could of saved if that's the case
Old Aug 17, 2016 | 05:14 PM
  #38
invstr55's Avatar
invstr55
Same here, mine is 46ft long and 13.5 tall so need about 60 ft...but in worst case I can always extend it the old fashion way
Old Aug 17, 2016 | 09:30 PM
  #39
johndeerefarmer's Avatar
johndeerefarmer
I don't care for the wired camera either but based on my experience with my 15 SD I am glad they went wired. I had three different brands of wireless cameras and as soon as you got above 10 mph and the truck's TPMS kicked in the camera image would start coming and going as the TPMS signal caused interference with it. It worked fine for backing (because at backing speeds the TPMS wasn't on) but I wanted it for a rear observation camera as well.
I plan on figuring out a way if possible to make the wired camera on my new truck be turned on all of the time not just when backing.
Old Mar 4, 2017 | 12:53 PM
  #40
CassR's Avatar
CassR
New Info?
Wondering if anyone has any fresh info on the auxiliary camera "feature" of only working in reverse gear. It seems that many of us spent the money for this system only to learn that it would not function while driving down the road. I'm very unhappy!! Am on the verge of buying an aftermarket wireless. But first I want to know if anyone has learned how to (without voiding the warranty) get power to the camera full time (including in forward gear!). Or, if anyone knows whether Ford engineers might actually be working on fixing this short-sighted design. TIA!
Old Mar 4, 2017 | 01:15 PM
  #41
wb6anp's Avatar
wb6anp
The 2 wireless systems I tried on my trailer would fail when I was in any campground that had wifi boosters in the park, wifi can interfere with them. Also remember part of the trailer mounted camera harness is also the repeater for the trailer tpms. The Aux camera only works in reverse. My understanding on its operation is that it is powered full time, but the chanel on the display wont turn on till you are in reverse.
Old Mar 4, 2017 | 02:26 PM
  #42
REPO.'s Avatar
REPO.
It will show up as an option with the tailgate and upper brake light camera. This screen only becomes available while stationary or in reverse I believe.
I would bet the aftermarket will come up with an option to allow you to turn them on whenever you want. I did this on my Ram with the 'MyGig Lockpick' it worked very well.
Old Mar 8, 2021 | 01:27 PM
  #43
MagicMtnDan's Avatar
MagicMtnDan
Is there a newer version of this thread for more recent/current models?
I have an F350 with the cameras including an optional auxiliary (trailer) camera. And my 5th wheel has a wireless camera installed on it. Is there now a way to use this wireless camera with my F350's camera system and display? If not, is the wired option still good and if so, how does the camera get wired (does the wire/cable actually run over top of the 5th wheel trailer?!).
<EDIT: Looks like this is the thread: https://www.ford-trucks.com/forums/1...5th-wheel.html >
Old Mar 9, 2021 | 08:42 AM
  #44
f350larry's Avatar
f350larry
My 2021 allows for using the "Cargo Cam" which is the high center mount stop light camera, and the Customer Placed Trailer Camera while moving. The kicker is they switch off if you come to a stop and start moving forward again. But going down the road, it's really nice to hit the camera button once for the Cargo Cam view, and a second time for the trailer cam.
Oh, and having owned a 34' travel trailer, and using a wireless camera and a secondary display to see the camera, I'm glad Ford offers a wired camera. I have to hook up the 7 pin connector on any trailer I tow, what's the hardship with plugging in another 12 in connector - right below the 7 pin connector? I guess I'm not a soccer mom.
Old Mar 9, 2021 | 08:58 AM
  #45
17 Oaks's Avatar
17 Oaks
OK, I am planning on buying a F250 this winter.
I watched the SD F250 videos online. I note that they are offering a camera option in which one of the cameras is a rear trailer camera that can be placed on the rear of your trailer.....
BUT...it looks to be hard wired! REALLY???
Hard wired so a cable will be flapping away on top of my trailer? for months? For thousands of miles?
There are aftermarket rear cameras that provide wireless and FORD makes a hard wired camera circa the turn of the century. WHY?
I have asked over and over to every FORD contact I can (e-mail Ford, in person at Ford presentations, dealer, Ford website) why FORD is doing this and I get that "its better", "put the wire inside my trailer"," because its FORD tough:, "talk to your dealer", "contact FORD".....
no one will address why FORD is using such OLD technology.
I'm just venting and hoping there are more FTE out there who feel this is a step backwards for FORD technology.
LOL, you are talking about the $375 option for user installed trailer camera ONLY (NO TPMS).
What is it HARD WIRED? Do you really need to ask?
Folks its HARD WIRED to integrate with your 360 camera system so you can use the in-dash screen and camera settings.
You want WiFi/Bluetooth or smoke signal, fine you are not going to see I on our screen, but you can buy a monitor to display it for you.
Here is how I did it: Take Ford user install camera system, attach to outfall, fish down thru wall and underneath and plug into the provided fixture I mounted on my rear bumper, beats the hell out of ****-poor wifi/bluetooth...
