2014 wipers dont work
Old Aug 8, 2016 | 03:29 PM
rmo5095's Avatar
rmo5095
Love the truck even though I haven't quite figured everything out yet. Started it this morning no wipers. No indication whatsoever just don't work . Owners manual shows 2 relays for it in the engine compartment. While getting owners manual out of glove box noticed a sealed plastic bag with both relays in it brand new. This seemed very strange! Swapped both relays and still nothing, anyone have any thoughts? Thanks.
Old Aug 8, 2016 | 05:16 PM
frakchered's Avatar
frakchered
I was just reading into a situation I have with this. It maybe something for you to look into. Mine will stay intermittent after I have shut them off. Only thing that has been working so far is to cycle the switch to full on and then back off.
Now, what I have found for my problem is the switch connections tend to wear out between off and stage 1 of the intermittent. It was recommend to replace the switch. RockAuto has it for $26 and change and the guy on the other post said it took about 6 screws and 10 minutes.
Not 100% it is your problem, but sounds like mine.
Old Aug 8, 2016 | 07:45 PM
AzPete's Avatar
AzPete
The relays in the glove box were most likely the ones needed to complete the trailer towing lighting.
I would bet on the multifunction switch.
Old Aug 14, 2016 | 09:45 AM
rmo5095's Avatar
rmo5095
Replaced the switch, still no luck, any thoughts. Find it hard to believe motor just stops altogether.
Old Aug 14, 2016 | 01:03 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
The relays you found in the glove box are for the tow package.
Old Sep 3, 2016 | 03:42 PM
rmo5095's Avatar
rmo5095
Anyone ever replace the wiper motor before
Old Sep 4, 2016 | 07:42 PM
bigdaddyII's Avatar
bigdaddyII
Not in this particular model truck, but the design has remained the same since 1997. It's fairly straight forward and self explanatory once you get the cowl off. You can see howl to remove the cowl and wiper transmission on YouTube on an 04-08 model, it's the same on these. Was the switch not the cause of your problem? I ask because it is odd that a wiper motor would poop the bed only 2 years in.
Old Sep 5, 2016 | 06:18 PM
Pgh Rebel's Avatar
Pgh Rebel
Are you out of warranty? Why not just take it back to the dealer as a warranty repair? I had the same problem as above, where the wipers would not turn off from intermittent. Since I had just purchased the truck used 2 weeks prior, the dealer did it free of charge.
Old Sep 6, 2016 | 02:02 PM
rmo5095's Avatar
rmo5095
Its not warrantied, checked the harness to motor there is no power.
75highboy390
29
Jul 14, 2013 10:27 PM
donmi
Aug 27, 2012 11:44 AM
80FlareSide
Jul 23, 2012 11:25 AM
73 ford guy
Feb 10, 2008 11:03 AM
DW2455
1978 - 1996 Big Bronco
Jan 18, 2004 10:47 PM
