Edge Juice???
Old Aug 7, 2016 | 10:12 PM
RAH4X4's Avatar
RAH4X4
Edge Juice???
I bought this Edge Juice for $100 this afternoon. All the research I've done has only come up with Edge Juice w/Attitude. "Attitude" does not show up on mine anywhere. Do I have a different one? I know mine shows it was manufactured in 2004 and everything I've found on these are posts from 2009 and later. Maybe mine is pre-"Attitude"?
I've read all about how much people dislike these but for $100 I figured I'd give it a shot because I don't have a ton of money for high buck tunes.
Old Aug 7, 2016 | 10:30 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Absolutely use it. "Attitude" is simply the name Edge gave to the display so it could display the power level and the information from the sensors it plugs into.
Old Aug 8, 2016 | 06:30 AM
RAH4X4's Avatar
RAH4X4
so, just to be clear, this unit will not display the information from the sensors? Should I run gauges along with this unit?
Old Aug 8, 2016 | 01:52 PM
HLS30's Avatar
HLS30
It will show boost psi, rpm, and egt (you will need to install the probe). It connects inline with the sensors, as you might have noticed. It will screw with your ODBII boost reading. It does something to not let it read over like 15psi, even on the "stock" setting.
Burroughs
Dec 23, 2014 09:23 PM
endobear
Nov 3, 2014 07:06 AM
Presa C
Mar 23, 2009 12:39 AM
MasterBlaster
Jan 13, 2007 11:16 PM
The Man
Aug 24, 2005 05:38 PM
