All gagues dont work the same!
Old Aug 22, 2005 | 07:56 PM
The Man's Avatar
The Man
I already had autometer gagues installed awhile back, Had the superchip programmer but wanted something with an on the fly adj setting, so i had the edge installed and they wired it and Probed the moniter so all the gagues work..
I noticed that the edge reads a 4-5psi difference than the gagues.. along with a 30-50 degree difference in EGT... Both EGT probes are only 1/2" apart on the Manifold so there shouldnt be a Temp defference..
Which would be the most likely to be wrong... Gagues or the Edge tuner?
Old Aug 22, 2005 | 10:55 PM
Todder's Avatar
Todder
The Edge is off. It reads boost from the MAP (not accurate), and the EGT is just computed wrong with the Edge.
Your Autometer guages should be right on the money.
Old Aug 23, 2005 | 02:50 PM
Mark at DPPI's Avatar
Mark at DPPI
The Man,
I found what was posted to be different my gauges vs Attitude monitor boost wise are spot on, the EGT on the Edge is a little higher (35-45 degrees) as we are an Edge distributor I got info that they calibrate a little high on the pyro to help the engine live from the possible driver not watching the temps. Kind of a built in safety factor etc.
Mark @ DPPI
Old Aug 23, 2005 | 09:36 PM
LasVegas F250's Avatar
LasVegas F250
I have the X-Monitor also connect though the MAP what is the differents in the boost numbers?
Old Aug 24, 2005 | 05:38 PM
Todder's Avatar
Todder
I believe the MAP senor can only read 33.8 psi so that is as high as it will show. As for actual numbers I sold my Edge before I installed all my new guages so I have no idea honestly. But someone around here can prolly answer that.
boehmtrent
Jan 16, 2015 09:25 PM
howlingwolf
Oct 15, 2007 04:14 PM
79 Camper Special
Jun 17, 2007 11:08 PM
Mysticle31
15
Sep 1, 2004 11:04 PM
