General Diesel Discussion
Fuel problems
Old Aug 7, 2016 | 07:26 PM
Marissa Ann Stewart's Avatar
Marissa Ann Stewart
Fuel problems
So I've had a problem with "air in the lines or water" as I tried to jimmy rig or fix the fuel supply line I believe that's what it is I'm not sure it's a steel hard line that runs from the fuel filter to the injector pump I've called everywhere even salvage yards where can I find it how do I fix this I have a 85 Ford F-250 6.9 turbo diesel please help me I know this is the culprit because I can watch it leak I changed all the hoses and clamps brand new
Old Aug 8, 2016 | 01:41 PM
Robert Frazier's Avatar
Robert Frazier
You could replace it with rubber fuel line.
Old Aug 9, 2016 | 03:30 PM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE.
the piece you need is called an "olive"
part#E3TZ-9K260-A filter to injector pump, 2 needed. purchase here:
E3TZ-9K260-A | SLEEVE FUEL LINE CONNECTOR | OEM Ford Parts for $2.54 each
part #E3TZ-9C397-A fuel filter inlet from fuel pump, one needed:
E3TZ-9C387-A | RING FUEL PUMP SLEEVE | OEM Ford Parts $1.86 each
Old Aug 10, 2016 | 11:33 PM
Ford_Six's Avatar
Ford_Six
Type4 on here has return line kits that include those and are reasonably priced. If the olives are bad, chances are the return lines are shot too.
Dieseloholic1
May 3, 2018 09:54 AM
cline9394
Oct 21, 2015 10:43 PM
DSprocket
Mar 5, 2013 07:09 AM
DieselNM
Jan 20, 2012 08:01 PM
tkcollin
Oct 31, 2003 10:29 PM
