1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Tires
Old 08-29-2016, 11:56 AM
ufvj217's Avatar
ufvj217
ufvj217 is offline
cool i will order one soon!
Old 08-29-2016, 06:38 PM
RedNNBlue's Avatar
RedNNBlue
RedNNBlue is offline
I've had both the BFG A/T KO2s and the Cooper Discoverer A/T3s. Currently I have the Coopers, and I'm on the fence about getting another set, going back to the BFGs, or going to the General Grabbers. I have plowed with both sets on my truck, and have had good experiences with both. The Coopers were not good in this last Feb blizzard we had, but they were also fairly worn (not down to wear bars, but with over 40k miles on them, they were certainly down to the last 25% or so). I found that for both sets of tires, when they were getting worn (say about 40% tread left, give or take), they weren't suited for deep snow and/or plowing efficiently. Otherwise, I certainly liked both sets of tires. The Coopers are much more quiet on the road and I think a little better on wet pavement.
Old 08-29-2016, 07:13 PM
joeytotalauto's Avatar
joeytotalauto
joeytotalauto is offline
I ran the BFG and the general AT2
I love my toyo's
I kick myself in the *** for not listening too some of my customers . I always assumed they were made in Japan ; but they are not . Made rite here in USA.
Toyo open country AT2 extream they also give a 45k warranted .
Coppers I never liked the quality . Toyo does have another in between tire called the open toed RT rough terrain . The pictures don't do the toyo justice . When they showed up I was glad I didn't get the RT . Meaning they were already way more aggressive than the general AT2 and way more than the BFG .
The truck drives better than ever . I still can't believe it .
Old 08-29-2016, 07:19 PM
ufvj217's Avatar
ufvj217
ufvj217 is offline
toyo is VERY common around here in my area (florida). they make great stuff from what i see, i've never ran them though. maybe in the future i will.
Old 08-29-2016, 09:48 PM
joeytotalauto
Man I gotta say it again . I been a mechanic for 33 years . Race sprint cars , modifieds, snowmobiles . Tires are everything .
These toyo's made me not buy a new Superduty .
Old 08-30-2016, 04:06 AM
Hoss416's Avatar
Hoss416
Hoss416 is offline
What did it take to get that ASE cert at 13 years old?
Old 08-30-2016, 04:44 AM
Hoss416's Avatar
Hoss416
Hoss416 is offline
Not to hijack the thread but, death wobble is mostly attributed to the coil sprung trucks. Before you go spend money on an adjustable track bar, I would recommend that you thoroughly vet all of the steering components first. Check the drag link and tie rod ends, the pitman arm nut torque (should be at 200 ftlbs), steering gear play, ball joints and hub assembly, and all bushings in the springs and track bar. This won't cost you anything more than an afternoon and will probably steer (pun intended) you in the right direction. From what I have found on different sites and threads, death wobble (again on the coil sprung trucks) is usually dealt with (notice I didn't say cured) by adding a steering stabilizer or camber adjustments.
Old 08-30-2016, 11:55 AM
Spamfritter's Avatar
Spamfritter
Spamfritter is offline
I had Toyo Open Country M/T's on my F-150. I've got Toyo Open Country AT II's on my current truck. On a previous 2WD truck I had some Toyo road tires and they were quiet, got good traction and rode smooth as hell.
I'm a big fan of Toyo's.
Gage2502
49
04-26-2011 07:06 PM
imaheelsfan
02-27-2010 10:58 PM
HMS
12-05-2009 10:29 PM
fatherdoug
09-20-2004 01:22 AM
kevsf250
12-31-2003 12:16 AM
Quick Reply: Tires
